Still having A/C problems - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 07-29-2011, 09:27 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Originally Posted by classicyuppie View Post
The FCM is located in the engine compartment, underneath the battery. You'll have to pull it and the fuse box first to access it.
Hope this helps.
The FCM has two bolts that hold it in place; if you look straight down from the front of the battery you should see them. They can be removed without taking out the battery; you will need a 10mm socket and a long extension and a telescoping rod with a magnet on the end.
My NB Family...
Tags
a/c , compressor , fan , pressure , switch
Problems with TVA hyakugojyuuichi Miscellaneous Hoo-Ha 8 10-18-2007 10:23 PM
3 problems Noviisi 2.0 Liter Gas 8 07-01-2007 01:56 AM
ABS problems Bret66 Questions, Issues, Concerns, or Problems with the New Beetle 1 12-13-2006 12:40 PM
2 problems kikilynk Questions, Issues, Concerns, or Problems with the New Beetle 4 12-07-2006 01:55 AM
Help with Problems AmyWalker 2.0 Liter Gas 6 12-28-2005 06:35 PM
