2006+ NB headlight replacement? - NewBeetle.org Forums
Old 09-09-2008, 04:56 AM
What?
Default 2006+ NB headlight replacement?
I've searched everywhere and cant find a DIY for a 2006 NBC headlight replacement.
All of the links refer back to the previous generation headlight replacement and that does not even come close to applying to the 2006+ cars
If anyone has any insight, I'd appreciate it. I found the hex head release screw, but the headlight still will not pop out.
Thanks in advance.
Old 09-10-2008, 03:46 AM
Maggadog's Avatar
A Touch of Gray
Foresthill, CA, USA
Car: 2006 Convertible
Hi.
I had the same problem. Be patient. There is a DIY for this on the site, but I do not remember the thread title.
However, because my memory is going, I made a copy of the directions. The thread has pictures, but my copy does not. Thanks to whomever I swiped this from.
Here it is. Hope it helps.
Tools used 5mm 1/4" drive socket with a 8" extension
Passenger side
1. Find the locking bar head just under the first fender bolt. There will be a lock/unlock graphic in front of it. Turn it clockwise until it stops. Photos 2, 3 and 4.
2. Using your extension push down saftey catch tab (stamped stainless steel with an X on it). Photo 5. While holding tab down push head light out from behind. Make sure you hold your leg in front of headlight so it does not jump out onto floor. It comes out really easy.
3. Change bulb and reinstall.
4. Relock the lock bar and close hood.
Low beam headlamp
H7LL
H7SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
H7ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H7XV XtraVision Halogen - The Brighter Light
H7CB Cool Blue Halogen - The Whiter Light
High beam headlamp
H7LL
Old 09-12-2008, 06:30 AM
What?
Thank YOU!!
I searched and searched and could only find the older gen headlight replacement instructions.
This is a HUGE help!!
Thanks again.
Old 09-22-2008, 03:12 AM
kds's Avatar
kdsRegistered Member kds is offline
WA, USA
Car: 2006 2.5L hb platinum grey
Angry head light help/driver's side 2006
I replaced the passenger side a couple of months ago after much aggrevation. Now the driver's side is burned out. I tried today, but found that the lever, which I believe is below the locking device, doesn't seem to release anything. Anyone have an idea where the release lever is? Or if it is the metal thing below the locking device, which way do you move it?
Headlight gasket replacement? cjmandrake Questions, Issues, Concerns, or Problems with the New Beetle 18 04-10-2011 07:44 PM
Headlight replacement Barnum Technical Modifications 9 02-20-2011 04:13 PM
headlight replacement dieseldiva Technical Modifications 19 02-13-2008 02:23 AM
2006 headlight replacement? josigna Questions, Issues, Concerns, or Problems with the New Beetle 1 11-12-2007 04:07 AM
Golf headlight replacement CoriBug Miscellaneous Hoo-Ha Archive 3 09-26-2006 11:47 AM
