99 Headlight Bulb Holder Cracked - NewBeetle.org Forums
Old 09-14-2008, 09:06 PM
Unhappy 99 Headlight Bulb Holder Cracked
Hello All,
Apparently there are different types of headlight bulb holders in NB. Some other people have written that you remove the clip and the bulb falls out, but I had to pry mine out of a black plastic casing. When I tried pushing the new bulb in the casing shattered. I need to replace it, but the other side of the yellow wire attaches to an electrical connector that looks like it needs to be pried apart to remove it from the headlight housing. I figured I'd better check with you experts before I break something else.
Thanks,
Kevin
Tags
bulb , headlight
Where to buy headlight bulb? bigcanoe Technical Modifications 4 07-10-2008 12:22 AM
What part is this and where to get it cheap? Bulb holder inside turn signal lense AuctionHugh Parts and Accessories 10 03-09-2008 01:58 PM
Right headlight bulb JOHNJ11 Questions, Issues, Concerns, or Problems with the New Beetle 2 02-04-2008 11:29 PM
Headlight bulb replacement Buglover Technical Modifications 16 11-03-2006 02:20 PM
WTB - Cracked/Broken Headlight Scarab 1 Market Place Archives 8 05-03-2006 09:21 PM
