DRL headlights work when "off", but turn off when lights turned on! - NewBeetle.org Forums
Old 09-30-2008, 02:13 AM
Atlanta, GA, USA
Car: '00 GL
Default DRL headlights work when "off", but turn off when lights turned on!
2000 NB, anyone else had this problem? I'm guessing a problem in my light switch? Anyone know how to remove it from the dash, and what to check?
Bobulator
Old 09-30-2008, 02:44 AM
I'm a little confused as to your problem...
The DRLs are supposed to run when the lights are turned off. They are just on when the car is on. When you turn on the switch, your regular headlights will turn on. So are your headlights not turning on at all when you turn on the lights?
Old 09-30-2008, 05:10 AM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
Could you be in "brights" mode and have both bright bulbs burned out? That's about the only thing that I can imagine would cause the problem you describe... have you checked the fuses?
2004 Ford Focus ZX3
Drive more, worry less.
Old 09-30-2008, 05:48 PM
Atlanta, GA, USA
Car: '00 GL
Sorry, I should have said more. The DRLs are the normal low beams, and they work when the light switch is turned off. They should stay on when the lights are turned on, but they do not. The high beams they work fine when I turn them on, but I can't get the low beams to go on with the light switch on. My handbrake is off, and that interlock switch is good, as the lowbeam DRLs come on fine when the lights are turned off.
Old 09-30-2008, 05:50 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
Sounds like failure of the DRL relay.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
Old 10-02-2008, 12:48 AM
Atlanta, GA, USA
Car: '00 GL
Can you tell me where the relay is? What it looks like so I can check or replace it?
Old 10-09-2008, 01:35 AM
Default Headlights
Anyone have xenon headlights? I has two burn out two weeks and I have to buy new assemblies at 5oo each.
Does this "Chip" work? Bosch 06a906032c BugCowboy Technical Modifications 5 09-20-2008 11:30 PM
"Open trunk" light wont turn off. apodaca Questions, Issues, Concerns, or Problems with the New Beetle 5 08-28-2007 09:40 PM
Just changed the city lights to led "07 Beetle" StealthTurbo 2.5 Liter Gas 1 07-02-2007 05:27 PM
"Bumper" lights front and rear-Hard to install? usmcrettop Styling Modifications 3 01-18-2006 01:47 AM
