so my mom has a 2000 vw bettle gls-5 speed
ive been driving it to school cause right now i dont have a car but anyways, i noticed a couple things whenever you let off the gas, or give it gas it jerks, not side to side, and its worse in the lower gears and after its been warmed up, if you try to start it again, itll somtimes die, so youll have to give it gas so it wont die, and just recently it seems to idle a bit higher, usually it idles at around 800, now its starting to idle at 1100 i was wondering what would cause this? i was thinking maybe the fuel pump or fuel filter it has 67000 miles, so just had the 60,000 tune up clutch is still good but the bug seems harder to get a smooth shift than from other manual cars ive driven and of course this one has electrical problems too that bugs are known for and also, going 60 mph in 5th gear, the rpms will be at like 2800-2900, dont know if thats normal or not? seems kinda high any help is appreciated Last edited by basskater305; 10-12-2008 at 06:38 PM.. |
The rpms @60mph look correct. Scan it for codes. Even if there's no CEL there might be some codes stored in the ECU. I think places like Autozone do the scan for free. Has the fuel filter been changed as part of the tune up? The jerking could also be your MAF or even O2 sensor starting to die.
so after school today i took the car to an automatic car wash
usually i wash the car by hand, and my mom never uses car washes, but i decided to use it, cause the bug seems to attract a lot of bugs and after the wash, it seemed like the jerking was barely noticeable now could it be that all the dirt and crap from underneath the car was causing it? cause havnet really washed under it in a while, and theres still a bunch of crap underneath it still? so could that be causing the problem it was all highway from the way back off the car wash, so i slowed down and shifted into 3rd, and again it was barely noticeable. then after i got home, shut it off, started it back up again, and started and didnt die but the idle is still in the 1000-1100 range Last edited by basskater305; 10-13-2008 at 05:45 PM.. |
Foreign (dirt/sand/whatever) contaminants usually do not affect the operation of a car unless the protective covers are missing. However, water can get into places, where those contaminants cannot.
Off the top of my head, I would inspect the coil/coil packs, spark plugs and wires, and the connections for the cam sensor, throttle body. |
went to autozone to see if there was any codes
passed, no codes asked the lady what she thought it might be, she said check the fluid levels, i asked if it could be the fuel filter, she said its a possiblity but would be having problems all the time not just when i let off the gas but we took it to the dealership today to get some of its electrical problems fixed and my mom asked them about the jerking, but they said its normal? seems kinda weird.. told em to check the tranny fluid just in case..but idk do you think it could be the tranny at all? |
| QUESTION?? 2000 1.8t | JIMBOBF | 1.8 Liter Turbo | 23 | 09-17-2008 02:43 PM |
| Only one key with 2000 Beetle GLX | zipster | 1.8 Liter Turbo | 12 | 09-15-2008 10:38 PM |
| 2000 Jetta with 180,000 miles...question | MichelleRoze | Water-cooled/Current | 2 | 05-25-2008 06:04 PM |
| 2000 New Beetle | Genesis | New Member Forum | 6 | 10-22-2006 03:34 AM |
| 2000 beetle tdi | tdi jerry | Transmission Talk | 1 | 10-20-2005 09:46 AM |
