I don't know much about it, but I think it's commonly referred to as the CCM. Try that in your searches to see if you get more hits. There's probably a bunch of info on the vortex and scanning it with VCDS might shed some light on your problem.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW 04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust. 57 Beetle Oval Window Sunroof 2 powerstrokes, Thing, Fox, Dune Buggy...... |
Thanks for the reply
I just spoke with some vw gurus from Niki Motors in Toronto. They played a bit with switches and windows and decided nothing is busted. All the parts are functioning as they should be but there is still no lights and alarm and stuff. They suggested that I should open door panels again and check connections and wires for lose contact or broken wire, which I will do tonight.I'll be back with results tomorrow ![]() Cheers |
Checked everything and couldn't find not even one mistake
I did a good job putting them panels back together . Finally,I decided to check all the fuses again, but this time using proper tools and not only visual inspection and .... Fuse number 14 ( comfort lights - 10Amps )was blown but I couldn't see it until I connected it to Ohm meter. Problem solved ![]() |
| Comfort sys comp fuse blows when rear defroster turned on | albin49 | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 03-14-2012 06:04 PM |
| Fan Control Module FCM | lunchindabox | Market Place Archives | 3 | 01-18-2008 04:09 PM |
| You like weird feeling experiences? Try this in the comfort of your own home! | jdesigns | Miscellaneous Hoo-Ha Archive | 14 | 09-11-2007 05:49 PM |
| Want to trade Sirius module for XM module | rkirkpat | Market Place Archives | 2 | 07-22-2006 04:27 PM |
| Comfort sys fuse blows when rear defog turned on | albin49 | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 12-12-2005 03:28 AM |
