Headlight - NewBeetle.org Forums
Old 11-12-2008, 08:45 PM
Stl5152733's Avatar
Julz bug
Springfield, MO, USA
Car: 2006 Bettle
Default Headlight
I had a headlight bulb go out replaced it was a pain.
Now the headlight will go on and off when you hit bumps. I locked the headlight back in like your suppose to do
Car is a 2006
2006 Salsa Red
XM Radio
Alpine amps
Rockford Fosgate Subs
Old 11-12-2008, 09:34 PM
I had that happen to mine when I first got it. I took it to the dealer to fix it, since it was still under warrenty so I'm sure if it was the bulb that was bad or if it was loose.
Old 11-12-2008, 10:16 PM
Stl5152733's Avatar
Julz bug
Car: 2006 Bettle
My wife called the dealer and they wont even look at it now snce we changed the bulb.
If you take it in there and it's not a factory bulb they wont warranty it
Does anyone know where you can buy that metal clip thats in the back. The metal part you have to press down on to get the assembly out.
Old 11-12-2008, 11:46 PM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
Go back in there and demand to speak with the manager or the dealership owner. That is a load of crap.
2004 Ford Focus ZX3
Drive more, worry less.
Old 11-13-2008, 01:32 AM
99Turbo's Avatar
Union, MO, USA
Car: 1999 1.8t, Silver
Default Headlight
Two things come to mind.
1-There are two bumps on the base of the bulb and two dimples in the socket. These need to line up for the bulb to sit down tight in the socket.
2-Be sure that the retaining clip that holds the bulb in the socket is clipped. If it is loose the bulb can bounce and lose it's ground.
Don't know how important that external retaining clip is, the manual says it may or may not be there. On my 99 there are no external clips.
Will
Old 11-24-2008, 05:28 PM
I went through the same issue. It's fairly straightforward. This has to do with the pins on the car side. You need two flat head screwdrivers, the ones that you use on a watch. What you do is take the two screwdrivers to narrow the gap between the two metal surfaces on the plug. Just put pressure between the two. Then, you want to use a flat head pliers, the one with no grating on it, to squeeze the pins on the cluster side together. Then, make sure they are aligned straight. Check out my other thread on this. I will post some photos of this the next time I take out the cluster.
2006 New Beetle TDI 5spd, Cream Exterior/Beige Leatherette Interior, Monsoon CD/MP3/SAT, Sunroof. 43K+ Miles on the clock. UNIDEN 538W CB, Firestik 3' Antenna, Hardwired Valentine1 X/K/Ka/Laser Radar Detector,ProParts Dual Gauge A-Pillar Pod with New South Indigo Boost & Water Temperature Gauges, connected to the dimmer switch for a perfect factory gauge match. Watch the video clip! http://www.youtube.com/watch?v=-iZv39lnmAs, Hardwired Craftsman Garage Door Opener
Old 11-24-2008, 05:33 PM
This is an '06, same as mine. There is a metal spring-like clip that puts tension on the bulb base. + and - on forced onto the contacts on the bulb. Once it has been put in, it does not play. This has to do with the contacts between the cluster assembly male plug, and the stationery base female plug. It is not make good contact.
Will
Headlight help BobTdi Questions, Issues, Concerns, or Problems with the New Beetle 6 01-05-2012 05:04 PM
Need a headlight or two bigsexyTDI Parts and Accessories 2 03-24-2008 03:14 PM
WTB: Right headlight Kenya_7 Parts and Accessories 4 10-23-2007 11:33 PM
Right HeadLight coiae 2.0 Liter Gas 2 04-26-2006 10:25 AM
