Suddenly getting loud squeak and loud click... - NewBeetle.org Forums
Old 12-03-2008, 02:15 AM
JEGSSR's Avatar
Mt Dora, FL,
Car: 04 convert triple cream
Default Suddenly getting loud squeak and loud click...
... from the left front suspension area when we go over bumps. Suggestions?
Old 12-03-2008, 04:15 AM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Usually, actually most often its the sway bar bushings in the front, may sound like one side but its likely both. As well the sway bar can strike a bumper on the drive shaft that is usually the loud clunk sound. If the car is sitting lower because of lowering springs or from worn springs or overweight vehicle at all its probably both. Sway bar bushings, a cheap easy fix the other depends if the springs are involved or not.
Old 12-03-2008, 10:56 AM
JEGSSR's Avatar
Mt Dora, FL,
Thanks; I'll swap them out today. Even if it turns out to be something else, they'd be a good preventive maintenance investment.
Old 12-03-2008, 10:58 AM
JEGSSR's Avatar
Mt Dora, FL,
Thanks; I'll swap them out today. If nothing else, it will be a good preventive maintenance measure.
Old 12-04-2008, 01:18 AM
JEGSSR's Avatar
Mt Dora, FL,
not the sway bar bushings. Noise is coming from the top of the strut tower.
Old 12-04-2008, 03:20 AM
Twizzler
All thats there is the strut mounts and bearings, how high up do the top caps of the strut mounts look under the wiper tray? If they are noticebly high you will need to change those out but its not normally the reason it makes those sounds, there is really nothing there unless the strut nuts are loose?
Old 12-05-2008, 10:07 AM
JEGSSR's Avatar
Mt Dora, FL,
It was a convertible top locator bushing~
LOUD engine start up Jerseydiva 2.5 Liter Gas 19 04-26-2010 05:02 PM
NBC Loud Noise! JGC843 New Beetle Convertible 7 10-27-2008 05:30 PM
What if I want it loud and more responsive? DSedov 1.8 Liter Turbo 10 05-07-2008 11:56 AM
loud buggin2662 Technical Modifications 2 12-17-2007 05:27 AM
Ansa Exhaust - Too Loud jerryguyot 2.0 Liter Gas 8 08-31-2006 12:02 PM
