What the title says
![]() Mine is an early '98 and thus no ABS. Not so easy to find this exact rear axle in the junkyard, so will the other one do? Just not hook up the sensors? Or would a jetta or golf axle work? If anyone's done an axle swap, I could sure use some guidance right now ![]()
Not sure if it's down to differences in axles, more than likely it's with the hubs and brakes.
Yeah I highly highly doubt that ABS vs. No ABS would require entirely different axles. Plus there's going to be a lot more involved than just changing it out. ABS is computerized so there is going to have to be some sort of programing in the cars CPU that will have to be done. Not to mention the booster for it and all of the related lines.
Albert H ![]() Elwood Blues: 1999 GLS NB custom Celebrating 12 years of ownership. As of yet un-named 2010 New Beetle Final Edition Herbie #6: 1959 Disney Movie car 1972 Super Beetle 1302 |
I'm trying to find a replacement axle that will fit, in the mechanical sense. The non-ABS axles seem scarce. |
ABS or No ABS it should be the same axle. The only difference would be in wheel bearing hub and that booster, which you can just ignore. Wheel bearings are cheap and I suggest you replace them together with rear axle bushings.
But... just to stay out of the dark room and stop guessing... here is a link to the nice web page where you can see all exploded diagrams and pictures of mechanical parts for all years of beetles so you can compare. Just register with your e-mail and ad a password and you are good to go. http://www.vagcat.com/ Good luck Ewa Last edited by Tesla; 12-15-2008 at 07:07 PM.. |
Here are the Wheel Bearings with Hubs Assembly, Rear Pair (OEM),FAG $134.95 set from MJM.
CLICK HERE Last edited by Tesla; 12-15-2008 at 07:08 PM.. |
the 1999 picture is for an ABS equipped car.
you can see the tone ring for the ABS as part #17 in the photo above.
OEM rear wheel bearings with hub assemblies. Includes quantity two (2), one for each side. Includes hubs, wheel bearings and speed sensors for the rear on both sides. This product fits: * 1998-2005 Beetle * 1999.5-2005 Golf/Jetta * 2000-2006 Audi TT 1.8T |
There's anonter difference in that mine doesn't have that speed sensor on it. Anyway, the point's become moot because Zlotan's putting a brand new axle on it. He's found a non-ABS one at the dealer.
Since the original poster's issue is resolved, I don't feel bad about hijacking...
If one were interested in retrofitting ABS (and traction control, etc. -- whatever the "best" thing available for the MK4 platform was), what would he need to do? |
find a wrecked beetle with the stuff on it you want.
buy it, disasemble it, and put any parts and wiring that is different to those systems on the old car. ABS unit and brake lines, All four tone rings, wiring harness to those rings, rear axle as we learned here, front hubs, all in all it can be done, but without a bentley, a 2 car garage and a 2nd car, I wouldn't even attempt it. |
I have the 2nd car and I have the Bentley, but alas, I don't have a garage! ![]() |
| Rack unit, rear axle, rear metal inner bumper... | DaveB | Parts and Accessories | 2 | 07-26-2008 02:43 AM |
| How to Replace a CV/Axle | vdubbugman53 | Technical How-To | 1 | 10-31-2007 08:31 PM |
| Inspecting the truck's rear axle. | AmyJane | Jokes | 1 | 08-17-2007 02:43 AM |
| Raising me axle? | theoblack | Styling Modifications | 7 | 09-29-2006 08:46 PM |
| Is the CV axle and the Front Axle Assembly one in the same. | scarabY2k | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 06-23-2006 01:40 AM |
