Timing Belt - NewBeetle.org Forums
Old 12-17-2008, 10:54 PM
Default Timing Belt
I lost the timing belt on my 2000 1.8T while driving on the freeway. I was a couple hours from home, so I had to have it towed to the only shop that was open on a Sunday. They replaced the timing belt, but said there were more problems with the motor. (the head and valves were shot) They said that it would be too expensive to fix, and they started looking for a used motor to put in it. They came up with one for $3000. Does this sound right? I don't want to be taken advantage of. I don't know what to do at this point. I still owe money on the car; I can't really afford $3000 plus whatever they are going to charge me for the belt and labor. Is it better to just not fix it? Maybe try to sell it? I love my car, I just have no idea what to do. Any advise? Thanks!
Old 12-17-2008, 11:00 PM
gforce1108's Avatar
Port Jervis, NY, USA
Car: 98 Beetle TDI
Most likely, you only need the head, or have your head rebuilt. I've seen some broken valves wipe out pistons, but even that is repairable. Find someone that regularly deals with VWs if you can.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW
04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust.
57 Beetle Oval Window Sunroof
2 powerstrokes, Thing, Fox, Dune Buggy......
Old 12-18-2008, 12:34 AM
raff's Avatar
Proud TOD Maiden Voyager
Valdosta, GA, USA
Car: 2006 Jetta 2.0t, 2006 Miata MX-5
If we knew your location, one of us might be able to recommend a repair facility.
The answer is blowin' in the wind....thanks to PP&M
Old 12-18-2008, 02:13 AM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
If you are mechanically capable you could do the repair work yourself, I did on my 2.0 when the head gasket blew. I was on a tight budget and worked on it when time permitted. It took me about eight months to do the work. The only thing that drove me crazy was getting the timing marks in the right place when I put it all back together.
Old 12-18-2008, 02:04 PM
gforce1108's Avatar
Car: 98 Beetle TDI
Good advice - especially since the place it was taken too obviously doesn't know anything about the 1.8T. They shouldn't have wasted time installing a new belt without pulling the head.
Old 12-18-2008, 05:27 PM
D2Beetle's Avatar
NB Yellow Trifecta
FYI - The link to my cylinder head rebuild. I did post (page 3) the cost of my efforts or at least the receipts that I could find, which should give you a ballpark cost.
Old 12-19-2008, 07:57 PM
Thanks for your advice. We decided to pull it from that shop and tow it the hundred miles back to where we live. The shop that I normally take it to said they could fix it for a thousand dollars less (maybe more). The first shop was obviously trying to take advantage. At one point, a mechanic there offered to take the car off our hands for $500!
YES, I did it! - Timing belt, water pump, accessory belt. antonym The New Beetle Experience 22 10-11-2011 03:50 AM
timing belt tdi electraglide 1.9 Liter TDI 5 11-17-2007 07:19 PM
Timing belt??? Trbowgn 1.8 Liter Turbo 2 10-07-2006 12:11 AM
Timing Belt Help tombo 2.0 Liter Gas 3 05-19-2006 09:22 PM
