Temp display is blank - NewBeetle.org Forums
Old 01-11-2009, 07:32 PM
GreenWhamO's Avatar
Westminster, CO,
Car: '99 2.0l green thing
Default Temp display is blank
The time works, but the temp display is blank.
"It will show the letter "F" when first started, but then it goes completely blank.
Changing it to Celcius results in the same blank display.
Any ideas?
Old 01-11-2009, 07:49 PM
FallinApartBoy's Avatar
I Want A 2.5T
Dayton, OH, USA
there is a temp sensor attached to the front bumper. its closer to the drivers side and right above the grill. kinda oposite to the tow hook. check to make sure that is plugged in all the way. sometimes they get messed up if you scrape your grill alot or if it comes out alot.
Old 01-13-2009, 04:31 PM
Beetlemania's Avatar
crank it up, suckers!
Broken Arrow, OK, USA
Car: 1999 Silver Aero GL
My display went out years ago when I killed my battery. I ended up having to remove the rearview mirror, unplug the electrical connector to the display for about 30 seconds, then when I plugged it back in the temp came back on. After you pop down the part with the clock and thermometer you have to pull really hard to get the mirror out, and it's a pain to get back up there, but it should fix it for you.
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings!
Mi Bacca es Chewbacca!
I'm one of those people. Whatever that means.
Old 01-13-2009, 10:18 PM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
In some cases you might not have to remove the mirror, just unclip the clock/thermometer housing to access the wiring plug.
Previously:
WTB: Beige Clock/Temp Display BUGSTUFF Parts and Accessories 6 08-18-2008 05:58 PM
Engine Light, Temp Display, CD Player??? HELP SNOW BEETLE LeineS Questions, Issues, Concerns, or Problems with the New Beetle 2 02-10-2008 02:41 AM
HELP! How do i reset my mirror temp display to read in celcius? diabolique Technical Modifications 5 10-07-2006 01:16 AM
Snowflake in outside temp display 1poorvw Questions, Issues, Concerns, or Problems with the New Beetle 11 04-26-2006 04:08 AM
Outdoor temp display lucian 2.0 Liter Gas 8 02-08-2006 03:39 AM
