Air conditioner fuse problem - NewBeetle.org Forums
Old 01-25-2009, 12:31 AM
Default Air conditioner fuse problem
After having a problem with the A/C compressor cutting off on my 2002 TDI and wiggling the 30 amp fuse on the fuse block, the problem seemed solved. Several months later, the problem arose again. I replaced the fuse block on top of the battery after the recurrence of the problem with no change in the situation.
Fuse #16 on the fuse panel keeps blowing after which the cooling fans will come on. Replacing the fuse will solve the problem and can sometimes fix the problem for a day or two or only 10 minutes. No resistance is felt when turning the fans manually so I am guessing that this is likely not the problem. My next guess beyond the cooling fan is the a/c coil.
Any suggestions?
Thanks
Old 07-05-2011, 02:39 AM
Default Fuse 16
I have the sAme problem with fuse 16, burned sometimEs, did you have any informationn about this problem
Rag Top Cleaner & Conditioner klhoward61 Paint and Body 3 12-03-2008 07:13 AM
Air Conditioner Fan Noise Izzie New Beetle Convertible 2 11-25-2008 05:55 AM
Air conditioner problems pitt4me 1.8 Liter Turbo 7 09-17-2007 04:07 AM
Air Conditioner Repair FineExampl Miscellaneous Hoo-Ha Archive 3 06-14-2006 10:35 AM
Air Conditioner Compressor bad vwfleh Questions, Issues, Concerns, or Problems with the New Beetle 4 05-18-2006 11:48 PM
