Removing Headliner Trim - NewBeetle.org Forums
Old 02-05-2009, 06:18 PM
Default Removing Headliner Trim
Sorry if this has been answered, but I can't find the exact answer to my question.
I need to replace the antenna base (wife closed garage while backing out!).
I have read on these forums that I need to drop the headliner down in the back while the hatch is open so I can remove the nut on the base.
My question is pretty simple -- the headliner is secured by a big piece of plastic trim. I can't seem to figure out how to remove this trim and have already broken one of the snaps/clips off underneath.
It APPEARS that the trim needs to be pulled down about 1/2" and then slid to the left or right, but it doesn't seem to budge.
The snaps/clips appear to be a "B"-type clip where something sticks into it and holds it in place. However, this is where the plastic on the trim broke off because I thought it would pull out of the "B"-clip.
Any help would be greatly appreciated!!
Tags
antenna base , headliner , rear , trim
How To: Remove Window Trim (B-Pillar Door Trim) Darkstar Paint and Body 5 05-22-2012 05:10 PM
Removing B-Pillar Trim? SMG Paint and Body 4 06-03-2010 09:35 PM
Headliner Help! GreenGroovy New Beetle Detailing/Cleaning 9 09-16-2008 10:27 AM
Removing New Beetle headliner ATT Questions, Issues, Concerns, or Problems with the New Beetle 2 08-23-2007 03:56 AM
Key fob & headliner problems Z06 Questions, Issues, Concerns, or Problems with the New Beetle 5 05-08-2006 02:50 PM
