Engine misfire - P0301, P0304 and P0134 - NewBeetle.org Forums
Old 02-12-2009, 05:40 PM
Default Engine misfire - P0301, P0304 and P0134
Hi Everyone,
This is my first post, and I'm actually posting on behalf of a friend.
Anyhow, my friend's Beetle started running rough recently and the check engine light would come on and off. Since it had been a while since the spark plugs were changed, we replaced the plugs and the wires, which made it a bit better, but then it came right back. The check engine light is on, giving the codes in the subject line (cylinder 1 misfire, cylinder 4 misfire and insufficient activity from O2 sensor 1 (before converter)).
The car is idling rough, and it seems to be running a bit rich (at least the exhaust fumes smell rich.) There is visible smoke if you rev it up.
One thing that concerned me - and I'm not sure what might happen if that was the case - it seems that the lube shop might have put in too much oil. When I pull out the dip stick, it appears to be at the highest level in the normal range, which leads me to think it might have been too full. I see warnings all over the engine compartment about overfilling. What actually happens if you put in too much oil?
Does anyone have any suggestions on what might be wrong? Note: the O2 sensor was replaced in 2005 under the recall. Also, the spark plugs are brand new, as are the wires. The mass air flow sensor was replaced in the last few years (not brand new, but not old).
Let me know what you think.
Thanks,
-Michael
Old 02-12-2009, 06:01 PM
Sorry, I forgot to mention that it's a 1999 2.0L engine.
What's the chance it's the ignition coil?
-Michael
Old 02-12-2009, 06:02 PM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
I think if there is too much oil ... the catalytic converter can break? I think that is what happens.
I hope thing get fixed up. Sister is having similar issues ...
J'veux pas mourir tout seule.
Old 02-15-2009, 04:16 PM
05yellowbeetle's Avatar
Middlesex, NC,
Car: Herbie '05 Yellow 2.0 GL
Is it worse after running through a water puddle? Is it worse on days with high humidity? If yes, then change the coil pack. If you already replaced both the plugs and the wires I would change the coil, they are known for cracking. Just before I sold my '98 my brother decided to clean the engine, so it shined. Good idea, except mine had a broken coil, didn't know that for sure until a bit of reading on here after I sold it. Anyway, the car spit, sputtered and in general carried on, it refused to run. My brother had to dry out the coil and the engine in general before it would stay running smoothly.
Old 02-15-2009, 09:31 PM
Thanks for the suggestion!
If coil pack refers to the ignition coil (link to picture of ignition coil: http://www.autozone.com/images/products/wl2/wl2c1319003.jpg), then we already tried swapping that out. No luck:-(. Are there other parts of the ignition system that tend to fail? Or might this be something other than the ignition system?
Thanks,
-Michael
P0301 Cyl 1 Misfire..can I drive car? CEL on. freddyjim 2.0 Liter Gas 13 03-11-2009 10:20 PM
O2 Sensor- CEL P0134 &P0135 blues18 Questions, Issues, Concerns, or Problems with the New Beetle 1 10-09-2008 07:30 PM
P0300, P0302, P0303, P0304 newbluebeetle 2.0 Liter Gas 2 07-21-2008 01:10 PM
P0171 & P0134: Replace O2 sensor? rauldejesus 2.0 Liter Gas 0 08-13-2006 01:51 PM
P0301 Cylinder 1 Misfire Detected Bugged in CA 2.0 Liter Gas 5 12-16-2005 08:25 AM
