Right front tire going bald on the inside edge - NewBeetle.org Forums
Old 02-24-2009, 09:15 AM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Default Right front tire going bald on the inside edge
I had a set of new Goodyear F1 put on my 2002 1.8t a month and a half ago, balanced, alignment done and now I have found the front right tire has worn dramatically on its inner half. The outside facing portion of the tread looks new, the inner portion you don't normally see unles the wheel is turned is nearly gone. The alignment was initially done incorrectly then done again by the same shop and now this. What sort of adjustments can be made on a Beetles front end, is it tie-rods only or is there any camber adjustments? I've been smelling burnt tire rubber this whole time as well. The wheels are stock 17" and are not rubbing anything, its simply the way the shop alighed them that is driving the edge of the wheel into the pavement.
Old 02-24-2009, 01:42 PM
kaiser's Avatar
no longer use this site
torrington, CT, USA
Car: 01 techno blue t3/t4 big turbo
tie rods and the ball joint can be adjusted.
the ball joint adj will affect camber.
sold the beetle, don't use the site anymore
Old 02-24-2009, 03:46 PM
MichelleRoze's Avatar
Auburn, Georgia, USA
Car: 2002 Reflex Silver TDI w/ 5 spd swap! (PAID OFF 3/14/14)
I'd say go somewhere else and get a real alignment. Sounds like they messed something up and it's not truely aligned.
I'd show them the tire after a month and a half, ask for a refund and go elsewhere. They should honestly give you a new tire as well, but I don't know if they will go that far. They need to back up there work and if you still have your receipt, then they should honor it. But I would just ask for a refund and get it done elsewhere!
"Probie"
smvwparts.com
Old 02-24-2009, 03:50 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
Agreed, take it to a different shop. Have them diagnose and document what was done wrong. The previous shop should replace your tire and refund the alignment charges.
2000 New Beetle GLS TDI
Old 02-24-2009, 04:10 PM
marvins_dad's Avatar
Roswell 2017 - 6/23-26th!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
I had that problem, though it was bad alignment after the accident...but it turned out to be a bad bearing...I think. I'll have to look up my paperwork to see what exactly they replaced.
marvins_dad ~ antoine
Old 02-24-2009, 04:52 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
Possible, but the car should be exhibiting other symptoms...noises/vibrations and such. And if the bearing is that bad that it would scrub off the tire that fast...it should be very close to a colossal failure and would be easily noticed.
Old 02-24-2009, 05:48 PM
bigsexyTDI's Avatar
Diesel Freak
Paducah, KY, USA
Car: '98 TDI
I would bet that the ball joint is bad.
SMAUG - '98 UNI-RED NB TDI, UPSOLUTE, SPRINT 205's, EIBACHS, BILSTEIN HDs, CAT & MUFFLERECTOMY, .:R32 ARISTOS, GENERAL EXCLAIM UHPS, 250K AND CLIMBING
Old 02-27-2009, 04:57 AM
Twizzler
Now I hear a clicking sound coming from the ball joint area under my feet while I'm driving. Why would a tire shop align a vehicle when the ball joint is noticeably done in? It obviously won't work out for the owner, this sucks. I'm supposed to bring it in for them to see next week, I'll update as this is an odd situation that others could benefit from in knowing the outcome. Thanks for the responses.
Old 02-27-2009, 12:18 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
Ball joints don't usually "click." They do pop or clunk, particularly when going slow and braking/turning. Audible clicking is usually the CV joint. If your ball joint is bad and the shop missed it, excess slop could cause extra strain on the CV's.
I really question this shop's ability and credibility. I would give them one more chance to make it right, otherwise take it elsewhere and try to get enough info to get your money back from the other shop.
Old 02-27-2009, 02:38 PM
Agreed! I don't tolerate shops that cause excess trouble or "miss" important things like that. If nothing else, they should have at least informed you if they saw something wrong and allowed you to accept a repair or refuse and deal with it.
I still agree that they should get you a new tire and refund the alignment. How much you get back from them depends on the fuss that you put up. And going through a tire that fast...I'd put up a BIG fuss! And then go somewhere else and get it done right!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
2005 Ford Ranger Edge Stl5152733 Photos: Other Rides 11 02-08-2009 03:06 AM
Bald Eagle BUGINME Miscellaneous Hoo-Ha 5 07-09-2008 07:23 PM
Protecting bottom edge of the front bumber? lmonsanto New Member Forum 1 12-18-2005 05:14 PM
Halloween Show at Bald Hill WNAB911 Event Planning Archive 4 10-29-2005 02:43 AM
Plastic Panel in front of spare tire underneath the car squeebug Questions, Issues, Concerns, or Problems with the New Beetle 8 10-06-2005 04:38 AM
