Squeak/Screeching noise after Engine starts? - NewBeetle.org Forums
Old 03-02-2009, 05:40 AM
AceJay's Avatar
beatmania IIDX
Princeton, NJ, USA
Car: '99 Techno Blue
Default Squeak/Screeching noise after Engine starts?
Basically about 80% of the time I start up my bug, it'll make this nasty screeching noise like if the enginge didn't want to turn over.
1999 2.0 Automatic
100k miles
Did 80k maint., none after
Changed and flushed oil and that wasn't it.
Any ideas? I don't know if the timing belt or water pump were done by the previous owner and I've gone 20k in 2 years so far...
'99 Techno Blue
Old 03-02-2009, 06:31 AM
DZLBUG's Avatar
Big Stig
Sauk Rapids, MN, USA
Could be the starter squawking...though that is more common on manual trans models. Timing belts usually give more of a "whoosh" sound at idle when going bad.
Have someone else start it while you have your head under the hood. If it's on the driver's side, starter. If it's on the pass side...timing belt related (roller, tensioner, etc) or something on the accessory drive.
If there is any doubt, which it sounds like there is, get your timing belt, water pump, rollers, tensioner and everything else replaced ASAP. Go with a quality kit that has a metal impeller water pump and make sure the one-time use only stretch bolts for the motor mount are replaced and torqued correctly.
2000 New Beetle GLS TDI
Old 03-03-2009, 03:33 AM
Sharonville, OH,
Car: 1999 GLS 2.0L 5-spd Silver Arrow
does it sound like this?
http://forums.vwvortex.com/zerothread?id=2269482
Old 03-04-2009, 01:51 PM
Phoenixville, PA, USA
Car: '00 Cyber Green GLS "Sweet Pea"
Ah I have this same problem as well. I took it to the shop and of course when they had it, it didn't make the noise. Mine was making a screeching noise in addition to a rough/stalled start.
I switched to using a higher grade fuel and occasionally put some cleaner in and it's been about two weeks since my car has had trouble starting or made that awful noise. So maybe you could try that?
Meet Sweet Pea <3
My Story
1/20/09 R.I.P Princess Daisy , I miss you.
Old 03-06-2009, 04:38 AM
AceJay's Avatar
beatmania IIDX
Princeton, NJ, USA
Beckweed: That's it exactly. Makes sense that it's been doing it only when it's relatively cold.
DZL, Emm: Yeah, I'd do all that if I had the money. I'm broke.
Also my ABS light decides to light up randomly, not cure if that's related.
Engine starts, then quickly dies I_love_orange Questions, Issues, Concerns, or Problems with the New Beetle 4 02-06-2009 01:09 PM
What's that squeak from my engine when I shift hard? spinjector 1.8 Liter Turbo 4 07-30-2007 06:33 AM
noise when engine starts mike 51 1.9 Liter TDI 6 05-01-2007 12:36 AM
Engine turning over followed by a brief screeching noise - What is that? ptmlinh 2.0 Liter Gas 5 11-04-2006 09:44 AM
another engine noise in my 2.0 - vag com callisto9 2.0 Liter Gas 12 11-16-2005 09:28 PM
