Driver side electric window switch,door light and door lock not working. - NewBeetle.org Forums
Old 04-10-2009, 09:12 PM
Default Driver side electric window switch,door light and door lock not working.
As above for some reason the electric windows switch does not work and the interia light dont come on when door opens plus the lock wont open when using the key phobe,only works when you use the key mechanically?
Is there a fuse for all of this if there is where abouts is it?
Old 04-22-2009, 12:41 PM
I still cant fix this,the door card is off with me now and the black metal frame work is off half way i see electrics going to the door lock would this cause the windows not to work and the central locking on the driver side not to work.
Please i need some info and help on this.
Old 04-23-2009, 01:34 AM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
I'm not certain I understand the problem; have you considered that it might just be a bad window switch?
Old 06-11-2009, 11:06 PM
Bump.
Installed radio and speakers in my Gf's car, and now the driver window, and driver power lock wont work from driver door. The lights on the switches wont even come on. The switch to open the passenger window from driver door still works though. Any suggestions?
Old 06-12-2009, 05:20 AM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
Probably your power mirrors don't work either. It likely is the module that is attached to the driver's power window motor. The power door locks and windows run through this module. It is sold as one assembly with the motor, not separately, but you can separate it from the motor by prying back the plastic retaining tabs (I did this to save myself the hassle of changing out the window motor). The dealer sells it for about $400. I found one at a German Car salvage yard for $60. You can change it out yourself...
Old 06-12-2009, 10:52 PM
I was thinking it could be the module also based on all the threads ive read on the subject, but the power mirrors do work.
The only things that don't work are the are the (driver window and door lock on drivers door) the passenger window does work from driver door.
Old 06-13-2009, 12:51 AM
Cool
It's likely that the module is not failing all functions at once. That's just what happened to me. My pass. window worked from the driver's window switch as well.
The salvage yard that I used includes a 60-day warranty on all of their electrical components. If a salvage yard that you contact offers no warranty, it may not be worth getting a used module...
Driver Door window not coming down to close door on Convertible zoedica New Beetle Convertible 10 10-14-2010 09:49 PM
Driver side door lock question steampunk Questions, Issues, Concerns, or Problems with the New Beetle 2 03-11-2009 10:47 PM
WTB: Window switch on inside drivers side door panel ninsei Market Place Archives 1 07-25-2007 12:41 AM
Driver Door Lock MrRadi8 Questions, Issues, Concerns, or Problems with the New Beetle 1 03-07-2007 03:36 PM
Driver Door Lock MrRadi8 2.0 Liter Gas 0 03-05-2007 04:50 PM
