Heater not as hot and blows cold when stopped - NewBeetle.org Forums
Old 12-21-2005, 10:18 PM
osprey's Avatar
Guelph, ontario, Canada
Car: 2000 1.8 T
Default Heater not as hot and blows cold when stopped
I recently had my water pump replaced,the timing belt, tensioner, roller the whole nine yards. At that time I also had the wedge bulb replaced behind the fan.
I have noticed that my heat is not as hot as it used to be even when it is turned to max/4. I do get heat but it doesnt heat up as fast and now have noticed that when I am stopped it blows cool, once I start moving it get warmer.
Any ideas ?
Could it be when the bulb was replaced the connection to the heater got shifted?
Thanks
Old 12-22-2005, 12:06 AM
speedie's Avatar
Eine Kleine Panzer
Lampasas, TX, USA
Car: 1968 Bug 2001 New Beetle 1.8T 2003 New Beetle 2.0
The bulb change will have no impact on heat level, but coolant not getting into the core will. Sounds like coolant isn't getting into the heater core. Perhaps there is is air stuck in there from the water pump work when they drained the coolant. Keep checking your fluid level in case the air works its way out.
I'm pretty sure you need VAG or another tool to check for air in your system. Call VW or a local mech who knows how to work on VWs and ask.
Old 12-22-2005, 12:21 AM
osprey's Avatar
Car: 2000 1.8 T
Thanks for the info, where would the air be stuck? In the heater core? Or the coolant line? I havent a clue!
Old 12-22-2005, 11:22 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
Could be either place. You can try "burping" the coolant system. With a COLD motor, just pull out the temperature sensor. If there is any air trapped, it will now escape.
After the car is warmed up, carefully feel the upper and lower radiator hoses. Are both warm, or one warm, and one cold?
Could be a stuck thermostat.
Engine Ticking While Stopped SMG 2.0 Liter Gas 48 03-27-2007 02:34 AM
cold air from heater njnewbeetle Questions, Issues, Concerns, or Problems with the New Beetle 0 12-19-2005 11:50 AM
Comfort sys fuse blows when rear defog turned on albin49 Questions, Issues, Concerns, or Problems with the New Beetle 0 12-12-2005 03:28 AM
please help! my monsoon cd player stopped sucking in cds! bigblock2336 Car Audio 1 12-09-2005 10:02 PM
