Burned fuse holder, replacement added, now toasted
We have a 1998 Turbo
>>>The more I write about this problem, the more I am answering my own questions.<<<< But please read and comment.
Yesterday, my wife was driving and suddenly, the cabin filled with smoke. Not good. When I looked at it, I quickly realized that I have an in-line fuse that had melted and smoked. (A little bit of electrical smoke goes a long way.)
I have attached a picture of the fuse holder. We are not original owners, and the wire is a direct feed from the + terminal. I do not recall the amperage of the fuse, and can't tell now. <<<<Now that I've gone to look at it again, I realize that the in-line fuse holder connected directly to the battery is necessary because one of fuses holder on the the 3-fuse box on the battery was charred. Pic below>>>>>> Read on.
A little history. A few months ago, I was having trouble with the battery running down daily. I replaced the battery and it continued. I took it to my trusted mechanic and they pulled all fuses, but could not locate the cause of the drain. (Charged me nothing). It kept happening. Because that fuse looked out of place (it is on a rather large wire, and attached with electrical tape to a much smaller red wire before it drops behind the battery), I investigated it. I pulled that fuse, and noticed that the fuse holder was rather tight and seemed to compress the fuse from side-to-side (almost making it short on itself). It seemed odd. I pulled it and determined that it is for the A/C somehow. (A/C doesn't work with the fuse out). I put it back in, the A/C started working again, and the battery drain problem stopped completely. I have had no problem with a dead battery for months. Rather odd, but it is working, so I forgot about it.
When I was messing with it today, I found a smaller red wire that comes from a 3-wire junction on top of the battery <<<the one with the charred fuse holder>>>. That wire was just dangling behind the battery, attached to nothing. My assumption is that this little red wire should be connected to what the big red wire with the in-line fuse is attached to. <<Yes, it must be since the fuse holder is melted, and not operational - the in-line fuse holder was added to replace it>>>
Is my assumption correct that the wire in question that used to feed from the box on top of the battery is for the A/C? It must be since the A/C doesn't work now, and didn't work when I pulled the in-line fuse,,,,,,right? Can this assembly be reasonably replaced?
