98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW 04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust. 57 Beetle Oval Window Sunroof 2 powerstrokes, Thing, Fox, Dune Buggy...... |
I had to replace my door latch module, and this write up was invaluable. Combined with these illustrations (see vwvortex link below), I can't say it was a piece of cake, but certainly do-able.
![]() VWvortex Forums: MKIV door locks explained - why you're having problems!!! ![]()
*2000 Volkswagen NB, Red TDI, running Dino *'82 Mercedes Benz 300D w/Greasecar kit, 40k grease miles and counting ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ http://www.chuckwyatt.com |
on the way back from the gas station tonight i discovered i'll need this how-to.
![]() nice write up. ![]()
Warren "And I think it's gonna be alright. Yeah, the worst is over now, the mornin' sun is shinin' like a red rubber ball." ![]() 1966, Paul Simon & Bruce Woodley. |
You gave me curage to do the repair with your little didy.. Thanks alot my window is fixed two hours later and $64.00 poorer from the dealer for the metal clips and cable. Great write up thanks for taking your time to help us all out..
Marc
http://newbeetle.org/forums/parts-accessories/44158-unofficial-newbeetle-org-decals-6.html Yes, Im in love with the Beetle. I have owned the NEW Ringo, Rico, JYD, and Peppy Pepper. I love this site and the people that come with it. I hope to see you and your beetle at a GTG soon. |
Has anyone ever had a problem with there door handle popping out when you try to open it? It seems like something is broken like a tab or something that holds the handle in so it doesnt come out to far....
I have pictures on a post here.... Broken Handle on my Passenger Side? |
Great thread! I am about to replace the regulator on my driver's window but the glass is in the full down position. How do you get to the two screws holding the window in place if the window is in the down position. Do you know if there is a way to raise the window?
Thanks!! |
Before putting everything back together I decided to check door lock assembly. Repaired microswitch sensed door state correctly and the light came up, however no other electric things worked
![]() I am unable to "lock/unlock" the car by "key" (screwdriver). If I use key fob, nothing happens with the lock (motor should lock it). I cannot lower passenger's window (I didn't install driver's window system at this moment). Should the battery be disconnected all the time while I'm taking the door apart? I thought that there was no smart electronics in the door just switches, bulbs, actuator. I don't see any malfunction lights on the dash. I have no OBD2 scanner at hand right now. I took the door apart and replaced that 4th microswitch with RadioShack's one. Since the counterpart was worn out, I left that metal bar that come with RadioShack's switch and glued it in reverse since there was no space left for drilling and I was lazy to do that. Since this thread is not particularly about the 4th door lock microswitch, I posted pics in original tdiclub's thread http://forums.tdiclub.com/showpost.p...&postcount=346 Do you have any idea what might be wrong? I don't want to start putting everything back now, since I won't be able to rise window regulator to secure clips. Last edited by mlt; 06-27-2010 at 04:43 AM.. Reason: link added |
Bummer! I missed the thing that there is the door control module near the window actuator. I guess electrics doesn't work since I didn't connect that module, but just door lock assembly itself. Is there a chance that I damaged control module while taking the door apart with battery connected? I just really don't want to put everything back together without being sure that everything is working as expected. The problem is that wire harness is quite short to check everything without actually installing... oh well.
Everything is working fine after I connected door control module :-)
I was scared when I was unable to lift the window all the way up to check if it goes smooth before securing bolts. Then I realized that it does go all the way up if I turn the ignition on. I'm not sure if it is expected behavior. |
This was a nice DIY on the door panel, window regulator and door latch removal. I think when you purchase a good Door Panel, a Window Regulator Kit and a Door Latch after removing it, things will go well and it will be a good car or a vehicle as a whole. Great job creating this DIY!
You are more than welcome... I don't get around here all that often anymore - too many other things going on. I just did a turbo swap (vnt15 for KP39 that was originally on my Jetta) on my beetle and should have documented it more. Not exactly plug and play ![]() |
I would have to agree on the posting. It helped out very much!! Just did this on my daughters car this weekend and without this posting I would nave been lost! Now she can lock her car at school and not have to worry about stolen stuff.
Thanks again, Bob ![]() |
I have replaced regulators numerous times on my 99 vw beetle. This time I couldn't afford to have the dealer fix it so I bought the kit from parts geek. Due to the fact there were NO instructions, my dad just started pulling things off and sticking the new pieces on... needless to say, didnt work out so well. The "spool" which has a spring and winds up came unwound. I now know that the reason there is a metal bracket is to prevent this. Is there any way to fix this or do I need to buy an entirely new kit? ):
I absolutely MUST say thank you so much for these GREAT writeups
. Sunkisd's driver's door latch microswith went bad all of a sudden (he "thought" the door was closed even when it wasn't) and I got ready to pay the 'stealership' more than $500 to replace it. But, then I came across this (and many other) VERY helpful how-to's that gave me the confidence to do it myself (I NEVER would have guessed I could!). I just finished and everything is working fine . My appointment was for tomorrow (not a moment too soon). In the end I only had to pay $140 for the new latch assembly. I am sooooo happy!! I must say I love how Beetle owners team up and help each other and avoid paying such RIDICULOUSLY high prices!! P.S. Even though Sunkisd is a vert, everything was pretty much the same, except one thing - the rear window bolt had to be removed (not just loosen it) - just for all the NBC owners out there. . I found this website that breaks down how to do this with a vert http://www.vwwebsource.com/vwtechsou...ssp/861303.pdf. This website, along with this great how-to, helped me A LOT.Last edited by imsos04; 05-18-2011 at 02:01 AM.. |
| In need of a passenger side door window regulator | ifxwrks | Parts and Accessories | 3 | 10-13-2008 05:46 PM |
| Door panel removal?? | ryanbutterworth | New Member Forum | 4 | 06-14-2007 05:59 PM |
| Door panel removal? | turbobug17 | Paint and Body | 1 | 06-09-2006 09:34 AM |
| Window regulator and Door Locks burn out | ACEKQJTEN | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 03-10-2006 11:10 AM |
| Having window problems - how do I remove door panel? | HadToHaveAY2Kbug | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 01-15-2006 10:48 PM |
