Is this clutch sold separately from the compressor? It stopped engaging just in time for the hot weather. Nothing is wrong with the cooling system other than the clutch engagement, I have not even been using the AC for quite a while. What sort of job is it to replace the clutch unit on the compressor? Any specific tools necessary. Thanks in advance for any and all replies.
And are you sure it is charged? If it is low on refrigerant it will not engage the compressor.
If you search through my other posts, you'll find a link to an AC troubleshooting guide. The clutch is available separately, but seems to be about the same price as an aftermarket, complete compressor. You can find them used. It's a little tight, but I've changed one while the compressor was still on the car (2.0 auto). One nut and a couple of snap rings.
Ohm out the connector to the clutch - I believe it should be about 4ohms.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW 04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust. 57 Beetle Oval Window Sunroof 2 powerstrokes, Thing, Fox, Dune Buggy...... |
Check this link out before purchasing a clutch. Mine wasn't working either.
I replaced the fuse panel on the battery. Cost for part was $100 at the dealer. No Compressor Operation in Volkswagen New Beetle
C-Dub
I checked that and have already replaced the whole fuse block on top of the battery because of teh infamous melting alternator line. What is the second red wire go to? On my car it is in poor shape now as well as the black alternator line. This image shows the wires in order for reference.
The other common problem is that the Fan Control Module is inoperative, which prevents the compressor and cooling fans from operating. If your engine cooling fans do not engage, this is the most likely culprit. Fan Control Module is about $90 and takes roughly 1 hour to change.
| new clutch/ not engaging | DRAGGIN89 | Transmission Talk | 0 | 12-03-2008 10:47 PM |
| Transmission not engaging | itsherbug | Transmission Talk | 2 | 10-28-2008 01:54 PM |
| Air conditioner problems | pitt4me | 1.8 Liter Turbo | 7 | 09-17-2007 04:07 AM |
| Air Conditioner Compressor bad | vwfleh | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 05-18-2006 11:48 PM |
| Air conditioner whisle | savethebluths.org | 2.0 Liter Gas | 1 | 04-15-2006 03:06 PM |
