Turn right, turn left - engine dies ?? - NewBeetle.org Forums
Old 06-23-2009, 06:54 PM
Default Turn right, turn left - engine dies ??
2006 5cyl 2.5, 6 speed auto, 20K. Here is what often happens.
stop at intersection
light turns green
pull forward 15 - 20 feet then
turn left or turn right to enter cross street
engine "fades"
step on gas a bit more
no response
count to 3 or maybe 5
engines "picks up"
and car suddenly surges ahead
Does not do this if I go straight through the intersection.
Any ideas?
thanks!
Old 06-23-2009, 07:19 PM
noR's Avatar
Administrator
Jackson, MS, USA
Do the rpm's fade; or just the torque? (I wonder if it's a clutch/torque-converter problem; or engine problem.)
noR | me | Phrog
PHROG
Old 06-23-2009, 07:24 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
The momentum of the turn is affecting the operation of the motor? Off the top of my head check the motor mounts.
Old 06-23-2009, 09:07 PM
Good question. I need to be more observant. Up till now I have been too busy looking at the car behind me rushing up on my rear bumper as I slow down.
Will try to observe ( maybe on an empty parking lot )and report.
............ and re motor mounts. That will be a challenge ( for me anyway) This effect does seem to happen more often the slower I go around the corner though.
Old 06-23-2009, 09:23 PM
noR's Avatar
Administrator
Jackson, MS, USA
When you turn, and try to go forward at the same time, it's alot harder on the motor/transmission. It takes more torque to move from a standstill if you've got the wheels turned. That's kinda where my head's at in trying to assess the situation.
Old 06-23-2009, 09:29 PM
SixChuter's Avatar
Bixby, OK, USA
Car: 2008 3W/2004 TS
My 2008 with the same set up does the same thing occasionally. Usually after a long run on the highway then an exit, the next time I stop and then accelerate there is maybe 2 seconds on no throttle response. Then it seems to wake up and go. Turning doesn't seem to be part of my problem. Seems to happen in hot weather. I've had the car 18 months and this has happened only half dozen times. It actually happened again today and it is 102 degrees and high humidity.
If you don't know where you're going....any road will take you there. G. Harrison
Lily's Pics
Gandalf's Pics
My Profile Album
Old 06-24-2009, 03:45 AM
[QUOTE=SixChuter;562724] ...... Then it seems to wake up and go. QUOTE]
That's a good description !
In my case, I have this happen maybe 2 - 3 times a week.
When it does happen, it repeats for maybe 3 intersection turns ..... and then it goes away.
I have now learned that the tack rpms do NOT rise until the car decides to get up and go.
Once, it behaved this way when stopped on a VERY steep hill.
Old 06-21-2010, 11:43 PM
Smile
Replaced 5 ignition coils. Problem has "almost" disappeared. ( go figure)
Old 06-23-2010, 07:50 PM
You can always turbo it
WI, USA
Could be a problem with the steering rack or something in the line for the power steering, causes the engine to bring up backpressure through the power steering system and tells the engine to shut down until pressure is relieved
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
Engine will not turn over but all aux items come on Babycar Questions, Issues, Concerns, or Problems with the New Beetle 16 07-16-2008 04:10 AM
noise after i turn off the engine--what could it be? coweyes411 Questions, Issues, Concerns, or Problems with the New Beetle 5 02-24-2008 02:10 AM
Left turn signal 2004 reen2000 Questions, Issues, Concerns, or Problems with the New Beetle 4 11-27-2007 09:49 AM
Left Front Turn Signal Miss.Panda Questions, Issues, Concerns, or Problems with the New Beetle 3 03-27-2007 12:56 PM
which way to turn engine sequoiagrapeboy 2.0 Liter Gas 1 01-24-2006 05:22 AM
