New beetle fault codes - NewBeetle.org Forums
Old 07-01-2009, 09:15 PM
Default New beetle fault codes
Hi,
I have a 2001 1.6 beetle and i got the trouble code P0030. Although this was not in the Haynes manual i found that it is O2 sensor. My dealer told me few months ago that my O2 had problem but i haven’t repair it. Few days ago i got P 0171 code (fuel trim, bank 1 lean fuel) and today i got a new code P1250 (fuel level too low). Are those codes related to the O2 sensor or my car start falling apart?
what you think i should do before visit my dealer?
Old 07-01-2009, 09:36 PM
noR's Avatar
Administrator
Jackson, MS, USA
Buy an O2 sensor and replace it.
Probably the front one.
noR | me | Phrog
PHROG
Old 07-02-2009, 06:48 PM
Default Is there any way to test it first
so i can be sure that this is the problem?
Old 07-02-2009, 07:07 PM
noR's Avatar
Administrator
Jackson, MS, USA
Not really. But if your error code says it's an O2. And the dealer verifies that the O2 sensor is bad. Yes, it could affect your fuel mixture and cause it to go lean.
I'm not sure what code P1250 could mean, it could be a whole different problem.
I think your best plan is to replace the sensor, clear the codes, and see what happens.
If you buy the sensor from autozone, they may offer to clear the code after you replace it. Ask them.
Old 07-03-2009, 09:12 PM
Default O 2 sensor
I can clear the code by my self this is no problem. I think i buy a new one and see what happen.
Old 07-06-2009, 05:10 PM
Default Reagarding the O2 sensor replacement
The code P 0030 means O2 Sensor Heater Circuit, Bank1 (Correct me if im wrong) That means that i have to replace the front sensor? or the rear?
ABS ground fault jc918t 1.8 Liter Turbo 3 07-19-2008 04:33 AM
2001 New Beetle engine codes? petah 2.0 Liter Gas 2 05-24-2008 03:54 PM
How do I pull engine fault codes? dsaldiv5 1.8 Liter Turbo 3 08-25-2007 03:33 PM
2002 new beetle codes roadman 2.0 Liter Gas 3 09-24-2006 06:14 PM
p1176 fault code notabeetleowner 1.8 Liter Turbo 2 12-19-2005 09:56 PM
