Stripped bolt help - NewBeetle.org Forums
Old 07-12-2009, 02:57 PM
lawlesseyes's Avatar
Lawlesseyes
Lake ronkonkoma, Long Island, New York, USA
Car: 1999 Yellow Beetle Turbo GLX
Exclamation Stripped bolt help
I posted this in the 1.8T section and haven't gotten any suggestions so I am posting it here in hopes of some. I really need to get the cover off to do some engine work.
My problem is....
I went to remove the cover off the engine. Got the right bolt off... great!
go to the do the left one and it just spins and spins!
Any ideas on how to get it off. I tried lifting the cover while unloosening, I tried going at it at an angle... nothing.
Help.
Old 07-14-2009, 10:32 PM
Albuquerque, NM, USA
Car: 2003 GL TDI
If the threads are gone, it's very likely not holding.
Just pull it off.
Kent Christensen
Albuquerque
'03 GL TDI, '07 GL320CDI, '06 E320CDI
Old 07-15-2009, 01:32 PM
noR's Avatar
Administrator
Jackson, MS, USA
it probably just unscrewed out of the block.
If it spins and spins when trying to remove it, it's not stripped; it's probably already out. Otherwise you were turning it the wrong way. (and if it was stripped by overtightening, it'd still just ... lift right out.)
So go ahead and lift the cover and pull it towards you to remove it.
noR | me | Phrog
PHROG
Oil Plug Stripped ! Daisey 2.0 Liter Gas 56 09-18-2010 03:52 AM
stripped bolt help! lawlesseyes 1.8 Liter Turbo 2 07-13-2009 09:12 PM
Oil pan (stripped) - my options ??? Cadenza Questions, Issues, Concerns, or Problems with the New Beetle 10 04-09-2009 12:36 PM
Tint stripped choppster1 2.0 Liter Gas 0 08-15-2008 05:09 PM
Stripped bolt lawlesseyes Questions, Issues, Concerns, or Problems with the New Beetle 5 08-28-2006 08:52 PM
