OK everyone, I have cleaned out the drains on my wifes VW Beetle & the water seems to not be getting into the floorboards anymore,
BUT I am still experienceing a lot of moisture forming on the inside of the windows, so much so it beads up and begins to run down the windows. Any Ideas on what might be causing this? thanks |
Something else that helps a little bit is when you are driving, turn the heat and A/C on and the recirculation too. The A/C removes moisture from the air. It's not quick but it does help.
Science flies you to the moon...Religion flies you into buildings
If you have a garage, put the car inside, open the doors and sunroof and side windows and aim a couple of fans so they blow air through the car. This will help the evaporation process.
Also, if you can somehow raise or remove the wet carpet the increased circulation will speed up the evaporation process. |
| Moisture around the Transmission | Zeka | Transmission Talk | 0 | 08-27-2009 08:20 PM |
| Inside Moisture | Tampa VW | 2.0 Liter Gas | 2 | 06-01-2009 05:59 PM |
| Cleaning the inside | vibelife | The New Beetle Experience | 1 | 04-26-2007 05:58 PM |
| My inside keeps coming on... | oiseau777 | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 02-24-2006 10:29 AM |
| Moisture on Headlight | Beaumont | Questions, Issues, Concerns, or Problems with the New Beetle | 7 | 02-11-2006 02:52 PM |
