Hey, there:
Just pulled these codes from my 99 New Beetle (2.0L). My ABS light (and occasionally brake light) have been coming on for a few months; I thought I might need to repair the ABS module, but wanted to get the codes to be sure. Do I just need to replace the speed sensor? I had pulled the airbag earlier this week in order to get to the wiper speed switch; not sure if the code indicates the airbag is installed incorrectly or this is just spurious. The airbag light was on before I downloaded the codes, but is gone now as we cleared them. I just installed a used instrument cluster, so I thought that might be part of the problem, too. Address 01: Engine Labels: None Part No: 06A 906 018 JG Component: MOTRONIC M5.9.2 HS V01 Coding: 00000 Shop #: WSC 07228 1 Fault Found: 16885 - Vehicle Speed Sensor: Implausible Signal P0501 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 G Component: ABS 20 IE CAN 0001 Coding: 03504 Shop #: WSC 00066 2 Faults Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) 35-00 - - 00283 - ABS Wheel Speed Sensor; Front Left (G47) 16-10 - Signal Outside Specifications - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl Part No: 1J0 909 609 Component: D AIRBAG VW3 SG 0002 Coding: 00068 Shop #: WSC 00066 2 Faults Found: 00588 - Airbag Igniter; Driver Side (N95) 32-10 - Resistance too High - Intermittent 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent |
| Airbag light | angieisgroovy | Questions, Issues, Concerns, or Problems with the New Beetle | 54 | 05-23-2011 01:43 AM |
| 2000 beetle driver side airbag resistance too low - cluster airbag light | turbobugger | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 07-22-2008 10:14 PM |
| Vag-Com Code for AirBag Light Results | chipndawn | 2.0 Liter Gas | 5 | 09-29-2006 03:42 AM |
| Airbag light | Fire_Dawg | 1.8 Liter Turbo | 5 | 08-02-2006 01:12 AM |
| WTB: Airbag | Deserion | Market Place Archives | 3 | 11-15-2005 02:09 PM |
