Need help changing headlight - NewBeetle.org Forums
Old 10-26-2009, 06:36 PM
virgo80's Avatar
Los Angeles, CA, USA
Car: 2004 GLS Galactic Blue
Question Need help changing headlight
My passenger headlight went out and I made a plan of replacing the bulb myself over the weekend. Needless to say, it was a big Fail.
All of the guides that I have looked at said to pull on the lever release on the side of the unit, push the back of the headlight and it should come right out. I did that.. and pushed so hard that the entire car moved, the headlight unit won't budge. I have an '04 GLS, so not sure if there's some special fancy detail that was overlooked that I need to do?
Old 10-26-2009, 06:53 PM
Are you sure that the lever is in tact? I know mine was broken, and its a pretty common thing to have happen since its made of plastic. My local shop had to get in my car with a screwdriver to get things unlatched.
Old 10-26-2009, 07:01 PM
virgo80's Avatar
The lever seemed to work fine. I was able to push it all of the way up with no problem. When I did that, the headlight unit made a slight pop, as though it had been released.. but it wasn't going anywhere.
Old 10-26-2009, 07:39 PM
You aso might need to get under the seal outside. I know mine was pretty stuck on.
Old 11-05-2009, 09:07 PM
rob11g's Avatar
NJ, USA
Car: 1998 Beelte 2.0L
Not sure you accomplished the removal yet. But if not, make sure you also release the strap that is located just above the plastic latch. The metal staping surrounds the headlight like a belt.
Changing Front Headlight To One Of These ??? leonardodecappiccuno Technical Modifications 3 04-08-2009 04:50 PM
changing convertible top ozg71 New Beetle Convertible 7 09-09-2008 02:07 PM
Changing a Headlight bulb on new beetles scott62 Questions, Issues, Concerns, or Problems with the New Beetle 8 10-05-2007 03:39 PM
Changing of the right front headlight mlegions 2.0 Liter Gas 7 03-29-2006 03:52 AM
changing the headlight every 6 months malnificent Questions, Issues, Concerns, or Problems with the New Beetle 0 10-31-2005 12:26 PM
