Dome and door driver light - NewBeetle.org Forums
Old 11-08-2009, 02:34 AM
Ottawa, Ontario, Canada
Car: 2001
Default Dome and door driver light
I have New Beetle 2001 - while open a driver door dome light or door light is not switching on ? Please help.
Thanks
Old 11-08-2009, 03:48 AM
Garage
You have a dead microswitch in your drivers side door. Very common fail point (still don't know why VW hasn't recalled them...). The microswitch tells the car if the door is open or closed. So when its dead, in your case, its telling the car the door is always closed, even when its open.
Old 11-08-2009, 07:40 AM
02newmag's Avatar
Reading, Reading, United Kingdom
Car: 2.0L 2002
happened to me, and i managed to fubar the switch, so i had to replace the whole lock, £40 from a breakers yard.for you be careful, it can be replaced easily just the switch just dont force it like i did.
Old 11-08-2009, 12:32 PM
Car: 2001
Thanks, I will try to remove switch gently. :-)
Old 11-10-2009, 08:53 PM
Talking
I had the same problem with my 99NB. I found it too $$$$$ & too difficult to keep taking the door apart. I fixed mine by getting a regular door jamb swith from a older Jetta and drilled a hole into the jamb, fed the wire 1 to a ground and the other into the door panel and tapped into the white w/ brn wire (the micro switch signal) works perfect cost ? $12.00
Old 11-10-2009, 09:04 PM
Wink
Hi sorry correction on the wire it is the bro w/wht stripe and my micro switch was good I had a problem with circut board. the switch had a seal and I used RTV to keep the water out
Old 11-29-2009, 03:52 PM
Kharma's Avatar
Fargo, ND, USA
Car: 2001 GLX
Oooh, my 2001 is doing the same thing. Thank you for this thread!
Old 05-08-2012, 08:46 AM
jeantyou's Avatar
i have meeted this thing before .i didn't care .but after sometime .the light was work regular .so far , i still don't know why ?
No one can change a person. But someone can be a reason for a person to change.
car led light
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Interior Dome Light 02 Turbo mrbeetlebrain Questions, Issues, Concerns, or Problems with the New Beetle 11 02-04-2010 06:17 AM
Driver side electric window switch,door light and door lock not working. Bug2003 Questions, Issues, Concerns, or Problems with the New Beetle 6 06-13-2009 12:51 AM
Newbie dome light question GreenWhamO Questions, Issues, Concerns, or Problems with the New Beetle 4 01-12-2009 12:54 PM
Interior dome and door lights flickering kickson Questions, Issues, Concerns, or Problems with the New Beetle 3 12-08-2008 11:52 PM
Sun Shade/Dome Light olive Questions, Issues, Concerns, or Problems with the New Beetle 2 01-06-2007 08:12 PM
