Headlight Bulbs Dropping like Flies!!! - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 03-06-2010, 08:05 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Have you checked the voltage going to the headlamps? High voltage will kill bulbs.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
  #22 (permalink)
Old 03-07-2010, 04:50 AM
SLIMEBUG
Katy, TX, USA
Car: 00 Cyber Green 1.8T
I haven't but I will the next time one blows (which probably won't be long).
What would cause a high voltage situation?
  #23 (permalink)
Old 03-07-2010, 02:41 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Poor voltage regulation, i.e., the alternator putting out too high of a voltage.
  #24 (permalink)
Old 03-07-2010, 04:05 PM
SLIMEBUG
Katy, TX, USA
Ah, makes sense. The voltage regulator on these alternators is internal correct?
Well, hopefully the daytime running lamp mod will help a bunch since daytime driving makes up about 90% for us.
  #25 (permalink)
Old 03-25-2010, 12:42 PM
SLIMEBUG
Katy, TX, USA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ANOTHER ONE WENT BAD!!!!!!! This makes number 6 or 7 in the 6 months we've owned the car.
I'll be checking the voltage this time.
  #26 (permalink)
Old 03-25-2010, 04:43 PM
There is a problem with your wiring harness inside the head light. I will find the link which describes it there is a TSB from dealers.
  #27 (permalink)
Old 03-25-2010, 05:57 PM
This will fix it !!!beetleheadlight.pdf
  #28 (permalink)
Old 03-26-2010, 02:49 AM
SLIMEBUG
Katy, TX, USA
So...it needs new headlight harnesses?
  #29 (permalink)
Old 03-26-2010, 01:40 PM
My passenger light was doing that and the wire harness, which is the one inside the headlight and includes the connector part of the headlight, fixed my problem. I actually have a brand new in the box vw one. I can mail it to you and try it for awhile, if your happy it fixed it you can then send me $35 plus what ever the shipping is, I believe I paid $65 at the dealer for it.
  #30 (permalink)
Old 03-26-2010, 02:40 PM
SLIMEBUG
Katy, TX, USA
65 bucks?!? For some wires?!? Shewt, I'll cut/splice this thing. I did notice that the jacket around the wire that connects to the bulb itself it cracked and fallin apart but I never though anything of it since that wire is not near any others or any metal to ground it.
I'm gonna cut/splice it. I have some of those connectors that the bulb has from my speaker building. The connector will be delicate but doesn't look too bad. It'll be a frankenharness.
Couldn't make it any worse!
I'll keep y'all posted.
  #31 (permalink)
Old 03-28-2010, 11:25 PM
SLIMEBUG
Katy, TX, USA
Ok, so I gutted one of the headlight assemblies (the one that was burnt out) removed the wire harness and rewired this punk. 65 bucks for 4 wires is RIDICULOUS! Hopefully, my electronics degree and soldering skills paid off.
Here's the before shots. As you can see, the jackets on all the wires are basically toast:
And here's the after shots:
So far so good. Both lights work and I installed ANOTHER new bulb in the headlight. We'll see how long this lasts.
If this works, I'll do a writeup when I do the other side. I will say, if you do not have fairly extensive wiring experience or don't have a LOT of patience working with small delicate things, this mod is not for you.
So far, my cost is $0 because I had the wire, heat shrink and connectors on hand. but if someone were to go buy this stuff, about 10 bucks for both sides would be reasonable.
  #32 (permalink)
Old 03-29-2010, 01:42 PM
Audiomechanic Nice work! Did not know your skill level thats why I offered the connector. I actually bought 2 new headlights for mine and the said they did not come with connectors but they did so thats why I have extras. Did you ohm out and verify the bulbs were bad ? or was it obviously blown and burnt? If you still have a problem after your fix I would say its because you change the wire colors LOL.
  #33 (permalink)
Old 03-29-2010, 03:57 PM
SLIMEBUG
Katy, TX, USA
Thanks! And I really do appreciate your offer. I apologize for not stating that earlier.
The bulbs were visibly burnt.
And as far as the wire color, the ground wire is now black, and no longer brown. AS IT SHOULD BE!
APC Headlight Bulbs FallinApartBoy Market Place Archives 5 07-03-2007 05:24 AM
Headlight Bulbs 2000 Corey 2.0 Liter Gas 1 04-09-2007 02:21 AM
headlight bulbs bugfreak Styling Modifications 4 04-02-2007 03:21 AM
Headlight bulbs osprey Questions, Issues, Concerns, or Problems with the New Beetle 6 05-12-2006 01:13 PM
