Exhaust joint leaking - NewBeetle.org Forums
Old 01-08-2010, 05:10 PM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Default Exhaust joint leaking
Whats the best way to fix the joint between the catalytic pipe and the mid muffler where VW clamps them? Mine is leaking after 8 years of service and starting to rumble the car. What are the diameters? Two clamps and a piece of pipe through the two?
Old 01-08-2010, 05:30 PM
noR's Avatar
Administrator
Jackson, MS, USA
Depending how big your leak is some paste/sealent may be enough.
Wurth Exhaust Paste Wurth makes GOOD STUFF.
You shouldn't have to replace the 2 clamps or anything, just tighten them again.
Do the job right and it'll probably stay good:
disconnect the joint, clean the parts, apply paste, apply clamp. Follow curing instructions.
Not sure how well that'll go over in your current environment, but it's a cost-efficient option.
noR | me | Phrog
PHROG
Old 01-08-2010, 05:34 PM
Twizzler
Sounds good but the pipes are well corroded. The clamp is basically part of the pipe that its clamping, its going to be time consuming to seperate it. I am looking more to cut that section out then replace whats missing. VW uses one clamp to join them, it's leaking pressure and gases right in the center of the clamped area.
Old 01-08-2010, 09:03 PM
noR's Avatar
Administrator
Jackson, MS, USA
Gotcha corrosion is no good. Another option than DIY is to go by a muffler shop and see who will do some light welding pretty cheap.
I had my Resonator removed, and all my seams welded up for $50. It was a bargain, I worked with him to have the car there on a slow-day. But it was worth the effort to me. He even used a piece of his own piping.
Headliner ala scarabY2k- A D.I.Y Joint scarabY2k Styling Modifications 226 04-23-2011 02:51 AM
CV Joint problem mariel Questions, Issues, Concerns, or Problems with the New Beetle 6 08-12-2009 12:14 AM
How to change a ball-joint? [lot] Questions, Issues, Concerns, or Problems with the New Beetle 1 06-18-2007 05:46 PM
CV joint, advice... antonym Questions, Issues, Concerns, or Problems with the New Beetle 19 05-05-2007 03:42 AM
U-Joint? Bob 2.0 Liter Gas 3 10-23-2006 10:57 PM
