Heater blowing cold air - NewBeetle.org Forums
Old 01-11-2010, 03:11 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Car: 2006 KitchenAid Red NBC, '66 Ford Mustang
Default Heater blowing cold air
My car has started blowing colder air when I am idling and warms back up after I start driving. Any ideas?
Old 01-11-2010, 04:15 PM
D2Beetle's Avatar
No NB Yellow Trifecta :(
Springfield, TN, USA
Car: Sliver '00 GLX Turbo / Yellow '14 Fiat 500L / Black '15 TSI Turbo
Off the top of my head, worst case scenario, a bad water pump or a stuck thermostat or perhaps it is just low on coolant.
My NB Family...
Old 01-11-2010, 04:18 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Thanks!
Old 01-11-2010, 04:20 PM
turbos03's Avatar
TX, USA
Car: 2003 Reflex Silver Turbo S... Sold
yup, any one of those three... or by chance it might be the temp sensor...
turbo lag n. The period of time between owning a 2.0 VW and trading up to a 1.8T...
Old 01-11-2010, 06:37 PM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
A faulty temp sensor will not affect the heat output. My money would be on the thermostat. They often will open too early or stay stuck in the open position as that is how they are designed to fail.
2000 New Beetle GLS TDI
Old 01-11-2010, 07:44 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Would that also make the temp light flash and beep at me?maybe those things are related?
Old 01-11-2010, 08:41 PM
Turbomania's Avatar
Returning senior member
Dallas, TX, USA
Car: 99 grn/Blk leather,1.8 T,5-sp, Eibach springs & Damped, -2"frt.-1.5" rear. 2.5 Tectonics SS ex, K%N
Default Red temp light flashing...
The flashing red temp. light normally indicates a low coolant condition. Have you checked the coolant reservoir?? It should be at the max mark when your engine is completely cooled off. It should read at the min mark when the engine is completely warmed up. Below the min mark when hot means it needs more coolant in it. Your temp sensor is working just fine, it's your coolant level that is probably too low for your water pump to circulate it through the heater coils at idle. If your car is not over heating than your water pump is probably alright but you do need to check and top off your coolant system with VW's G-12 coolant or what ever is called for for your years model. Have you had the cooling system worked on recently and then re-filled?? If so, it's possible that they did not re-fill it completely. Air can get trapped in the cooling system if it's re-filled without giving it enough time to completely fill up. The engine has to be warmed up and run at a high idle so the coolant can circulate and remove all the trapped air. Check for leaks and that tell tale anti-freeze smell when your car is warmed up. Good luck with this, JK
Turbomania
Old 01-12-2010, 05:36 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
Thanks,coolant level is fine, taking it in on Thursday.
Old 01-12-2010, 06:58 PM
Garage
Have you had your timing belt/water pump replaced?
Old 01-12-2010, 09:08 PM
OH, USA
Car: 03 GTI
It's an '06, so a 2.5L--no TB.
Wasn't there an issue w/ heat in the early 2.5L NBs?--I think I remember hearing something about that? Mighta even been a TSB put out IIRC.
Old 01-25-2010, 08:35 PM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
They said it was temp sensor and that the light and the cold blowing air were both from that. Only 1800 miles of my warranty left. They have to order the part so I have to take it back in a few days. Also got a coil recall letter on Saturday and had that taken care of.
Old 01-25-2010, 09:37 PM
turbos03's Avatar
TX, USA
like I said, temp sensor... good news and glad it was nothing serious...
you're welcome..
Old 01-26-2010, 02:17 PM
D2Beetle's Avatar
Glad to hear your problem was solved and still under warranty.
Old 01-26-2010, 09:08 PM
Turbomania's Avatar
Dallas, TX, USA
Default Temp sensor...
Can anyone explain the relationship of the faulty temp. sensor and her heater that would not put out warm air??? I can understand the red temp. light coming on but the heater??? Anyone??? JK
Old 01-26-2010, 09:35 PM
D2Beetle's Avatar
Old 01-28-2010, 02:20 AM
shellbug's Avatar
Achtung Baby
Martinez, GA, USA
you're welcome..
You are my hero!!
Old 01-28-2010, 12:43 PM
turbos03's Avatar
TX, USA
because its a VW....
Old 01-28-2010, 12:44 PM
turbos03's Avatar
TX, USA
You are my hero!!
just glad I could help.... same thing happened to a buddies MK4 Gti couple of years back and after changing the water pump and thermostat the only thing left was the temp sensor... swapped it out and bingo, heat... all that work for nothing..
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
A/C Blowing Cold Then Warm, Humid Air... _goREDgo_ Questions, Issues, Concerns, or Problems with the New Beetle 34 03-31-2016 09:22 PM
Heat blowing cold CTug New Member Forum 2 12-19-2009 03:53 AM
ac/heater blower quit blowing luvmybug09 Questions, Issues, Concerns, or Problems with the New Beetle 3 06-23-2009 03:08 PM
heater blowing warm air (doesnt get hot) sparktikus 2.0 Liter Gas 4 11-28-2008 10:11 PM
1998 beetle the air and heater just stop blowing any air at all what could cause this Red1999Beetle Questions, Issues, Concerns, or Problems with the New Beetle 1 06-21-2006 03:49 PM
