Door damper bolt? Help! - NewBeetle.org Forums
Old 01-16-2010, 09:56 PM
Unhappy Door damper bolt? Help!
So today the front driver door refused to close.
Upon investigation it looks as though a bolt has broken and the alignment between the 2 parts is causing the issue. I grabbed onto it with a pair of vice grips and was able to close the door, but I need the permanent fix.
Where would I find this bolt and how do I get it back in?
Thanks in advance for any help!
Here is the broken bolt:
and here is where it came from:
Old 01-16-2010, 10:09 PM
Turbomania's Avatar
Returning senior member
Dallas, TX, USA
Car: 99 grn/Blk leather,1.8 T,5-sp, Eibach springs & Damped, -2"frt.-1.5" rear. 2.5 Tectonics SS ex, K%N
Default Bad bolt....
VW parts department will have this bolt... It can't cost very much at all. I would try and determine why the bolt broke off in the first place or you might just have it happen again doing even more damage. JK
Turbomania
Old 01-17-2010, 03:51 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Haven't heard of a check strap breaking before.
Previously:
Old 01-17-2010, 04:54 AM
Default passenger
I check the passenger side and its broken as well......
The strap pulls out fine with a pair of vice grips.
Im just wondering if I get a bolt from the dealer how can I get it back in, I think it will not be an easy job.
suggestions?
Tags
bolt , door
01M pan bolt torque? 03nb1.8t Transmission Talk 7 11-23-2009 12:52 AM
Bolt pattern??? WNAB911 2.0 Liter Gas 10 07-04-2009 01:03 AM
Damper Problem I think! Lew Questions, Issues, Concerns, or Problems with the New Beetle 4 11-25-2007 04:19 PM
FS: sport damper (new product) johan_soeriohadi Market Place Archives 7 09-25-2007 11:30 PM
Fs: Mk4 Bolt On Parts Zookie The Canada Corner 7 05-03-2006 04:49 PM
