intermitent blend doors - NewBeetle.org Forums
Old 02-09-2010, 08:18 PM
Default intermitent blend doors
I have a 07 2.5 and the strangest things or going on with my blend doors for the ventilation system. On start up air comes out as normal but after around 10 min it backs down to a slight breeze. If I leave it system on 4, full blow it will continue to blow hot or cold air. If I shut her down for a while it works as normal and then is slows down. I could hear the blower crancking away. Any of you guys experianced like this.
Old 02-09-2010, 10:35 PM
jailor8's Avatar
Jailor8
IL, USA
Car: 2000 Beetle GLS 2.0 auto
No experience with this problem, but I'll think out loud here.
Could the bushing on the door arm as it passes thru the case be broken/cracked and the door is moving in the breeze on its own? That or the foam is coming off the doors after just 3 years? Sounds like something is blocking the flow.
Just a guess.
Jailor8
Doors won't unlock! ashers87 Questions, Issues, Concerns, or Problems with the New Beetle 1 09-14-2009 01:51 AM
Lambo doors? MichelleRoze Styling Modifications 3 12-31-2008 06:08 PM
Doors looking pretty bad =( NRamirez16 New Beetle Detailing/Cleaning 15 05-27-2008 08:33 PM
Why Not 4 Doors? 13Beetlejuice13 Styling Modifications 35 02-12-2007 01:16 AM
I need two new doors Tuckervill Paint and Body 0 09-28-2005 05:48 PM
