auto transmission lever stuck, wont shift out of park! - NewBeetle.org Forums
Old 02-15-2010, 04:03 AM
Los Angeles, CA, USA
Car: 2004 Turbo VDUB
Unhappy auto transmission lever stuck, wont shift out of park!
After my vehicle sits for several hours, I depress the brake, the light from the parking gauge on the shifter goes off but the gear shift will not move. I have to force it and sometimes it takes five or six times to disengauge and move into drive. Anyone has had this problem? I dont think its the trans, probably a computer switching mechanism or whatever. Help please.
Old 02-15-2010, 10:53 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
What color is your brake switch?
2000 New Beetle GLS TDI
Old 02-16-2010, 12:02 AM
BUGSTUFF's Avatar
New Beetle Accessories
Bartlett, IL, USA
When you depress the brake, do you hear a relay clicking underneath the dash or the center console? Check to see if your brake lights are coming on. Sounds like a faulty brake light switch, which was a recall issue. The next time it happens try depressing the brake pedal over and over, listen for the relay click and then see if you shift into gear.
Kirk & Pam & "Key Lime"
Northeast IL VW Association
Volkswagen Club of America
Old 02-16-2010, 01:01 AM
Yello_jellybean's Avatar
Can you handle it??
Denver, CO, USA
Car: 2005 Platinum Grey TDI GLS /DSG
When did you buy your car? Do you know the vehicle history?
Have all your recalls been done?
I know, I know... Whoa! WAY too many questions right? The reason that I ask is that.... on my 2003 NB I had this issue and it turned out that it WAS the brake light switch. (BUGSTUFF is right) The brake light switch is a recalled item on our cars. Mine was still under warranty, when it happened, but none the less, the dealer won't charge you for it if it hasn't already been done.
You see it got really, really hard to shift out of park, even with the brake pedal depressed. It got so difficult that at one point, I could not get my car out of park one afternoon. I had to call my husband to come home from the firehouse and rescue me.
That in itself, was not an easy task, because firefighters cannot just come home whenever they want. He ended up forcing it, or something...I don't really remember, but somehow he got it unstuck. In the mean time, I was on the phone with my dealership, flipping out. It is apparently an easy fix. Check it out my friend. Good Luck!
auto tranny wont shift, stays in third powerplayer256 2.0 Liter Gas 3 08-19-2009 08:30 PM
Would anyone be interested in a shift lever cover if I made a few? 1.8beetle Styling Modifications 1 01-29-2009 11:46 PM
1999 beetle wont shift out of park rrogers Transmission Talk 5 10-22-2007 05:34 PM
Stuck in Park rob11g Questions, Issues, Concerns, or Problems with the New Beetle 9 08-10-2007 02:07 AM
99 coil went out, now auto trans wont shift into 4th abrison Transmission Talk 0 01-06-2007 05:10 AM
