Blend Door DIY - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 08-23-2010, 11:34 PM
casrhino's Avatar
RHINO
oakland park, FL, USA
Car: 2002 1.8 turbo Riviera Blue / 2003 convertable Aquarius Blue
It will probably have to wait that long anyway I work 6-7 days a week and almost never have time to work on the car. Look forward to the pics. Thanks.
  #22 (permalink)
Old 09-04-2010, 05:07 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Well the finale has begun. I will be updating jailor08 original post this week end. For the purposes of this DIY I removed both front seats which IS NOT necessary to do the work; this was done to make it as easy as possible to get the photos taken.
Click Here to go back to the beginning of this DIY...
If you want to remove your seats, here is the DIY for that.
My NB Family...
  #23 (permalink)
Old 09-05-2010, 02:42 AM
D2Beetle's Avatar
NB Yellow Trifecta
Instrument Cluster DIY added...
  #24 (permalink)
Old 09-06-2010, 11:08 PM
D2Beetle's Avatar
NB Yellow Trifecta
The dash has been completely removed and here it what your NB might look like with it removed...
  #25 (permalink)
Old 09-07-2010, 12:24 AM
casrhino's Avatar
RHINO
Did mine a couple of days ago. The air is colder than I ever remember. I now realize that my 03 vert's air is not blowing as good as it should. Reached under the dash and the snap bushing is broken on that car too. What are the odds?
  #26 (permalink)
Old 09-07-2010, 01:28 AM
D2Beetle's Avatar
NB Yellow Trifecta
As it turns out, mine is not the snap bushing, read this thread.
  #27 (permalink)
Old 11-07-2010, 07:33 PM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
I am at pic 28... just snapped my ratchet!Before that it took me 4 hours to remove driver`s air bag! Nerv wracking!!?? I ended up making a cut in steering wheel rubber side then push the spring down and SNAP! Both sides unlocked in 3 minutes. I was so happy just to snap my only wratchet 5 minutes later on steering wheel nut. Which tork wratchet is reccomended and what would be a tork on that nut? ( .. and other nuts? ).
Now I am at full stop, regrouping and taking a day off.
Will post some pictures but need a break now.
Thanks for this DIY again.
Go out and ride
SPEEDLE
  #28 (permalink)
Old 11-12-2010, 02:21 AM
D2Beetle's Avatar
NB Yellow Trifecta
The steering wheel nut does not require a lot of torque, because you need to make an alignment mark, which you use to realign it when you put back together and you are suppose to use lock-tite.
  #29 (permalink)
Old 11-22-2010, 07:39 AM
Default rotten smell coming from dashboard
guys this is really helpful, i did the first steps to remove the cabin filter and i cleaned it smoothly, i also want to ask is there any other filters on the driver side? or from down
cause i have some rotten smell coming out even after cleaning the cabin filter (this has nothing to do with the AC, it's happening even without opening AC)
experts please advise
regards
  #30 (permalink)
Old 11-25-2010, 03:23 PM
D2Beetle's Avatar
NB Yellow Trifecta
regards
It could be either or both... the drain tube for heater core is clogged ... the foam on the blend door is rotting and growing mold.
  #31 (permalink)
Old 12-08-2010, 10:34 PM
Default Foam from Defroster only—same issue?
Hey, there:
Yesterday I noticed small pieces of foam blowing out of the defroster; was using it on A/C setting to defog window on cold day. Small pieces so far (maybe 1/4" or less in area), thin gray foam.
I kept flipping the mix switch from heat to defrost today until it all blew out. Wasn't much in total, just small bits. Heat seems to be working fine, so I'm wondering if this is the same issue.
Any thoughts or things to check?
Thx-
-Mark-
  #32 (permalink)
Old 12-08-2010, 11:21 PM
D2Beetle's Avatar
NB Yellow Trifecta
Originally Posted by mrmambo View Post
Hey, there:
Thx-
-Mark-
Yes, it is the same. The foam is coming from either or both of the Defrost/Heat door(s). The foam is dry rotting and disintegrating and as a result gets blown out through the vents.
  #33 (permalink)
Old 02-27-2011, 03:32 PM
Savannah, GA, USA
Car: 2000 N.B.
...after fixing the blower motor speed switch (I removed the entire control panel) my A.C. is no longer cold. since I had a hard time getting the cables on and off, got a feeling it may be the blend door....gotta get this done soon summer is coming and its my wife's car.
any quick temp. fixes just to make sure this is the problem without taking the entire dash apart? I know eventually I am going to do the full repair (foam replacement and clean and paint the deteriorating interior coating) just want to be able to use the car's a/c until I can get to it.
  #34 (permalink)
Old 06-07-2011, 11:01 PM
Warren, OH,
Car: 2000 Beetle
How can you know for sure that the blend door is bad?
I have low heat the last 2 years, but never had foam blow out of my vents. I just flushed my coolant and the heat is still low. I'd hate to spend all day tearing my dash out just to find the door is intact.
Is there a way to check it first?
BTW my cable clips are fine.
  #35 (permalink)
Old 06-10-2011, 07:38 PM
D2Beetle's Avatar
NB Yellow Trifecta
You might want to check the heater/defrost cable attachments. If these attachments are broken, the dash need not be removed to fix it.
  #36 (permalink)
Old 06-10-2011, 07:45 PM
D2Beetle's Avatar
NB Yellow Trifecta
It is not really the "blend door"; the blend door is wrapped with foam and that foam dries out and start to flake off. So at some point it blows out through the vent.
There are two other possibilities; the snap bushing and/or the defrost/heater cable attachments. These can be checked without taking the dash apart.
In the first post on this thread is the thread link for checking the cable.
Regarding the snap bushing if the cable moves you should hear the doors move, if not the snap bushing may be broken; that is what connects the door lever to the door.
intermitent blend doors rpellecc Questions, Issues, Concerns, or Problems with the New Beetle 1 02-09-2010 11:35 PM
Door handle (drivers side) minus door lock and mirror switch msmidi Parts and Accessories 1 11-12-2009 04:47 AM
FS: Glovebox, int. door handles, dash panel, rear door panels GINA Parts and Accessories 8 07-08-2009 07:53 PM
Driver side electric window switch,door light and door lock not working. Bug2003 Questions, Issues, Concerns, or Problems with the New Beetle 6 06-13-2009 01:51 AM
FS: Door Panels, Air Intake Box, Dash Grab & Door Handle Charlene_Bugy Parts and Accessories 0 12-21-2007 09:19 AM
