Help pls (lights) Possible ecm?? - NewBeetle.org Forums
Old 03-11-2010, 09:58 PM
Default Help pls (lights) Possible ecm??
I have the high beams stuck on. Here is what I did. I installed xenon lights... I know no one seems to like them. At first I had them with no relays! (I know .. not smart)
The high beam light was like a strobe light on the cluster.. but high beam bulbs were not on, I neglected for to long (3 weeks).... Now my dash light is on solid and so are my bulbs all 4 ( 2 low and 2 high) all the time even with drl. I can't turn on fog lights because highs are always on.
I have unplugged the dimmer switch on steering column and problem persist.
I unplug the light switch on dash and good news all my lights go off. But if I pull on dimmer switch to pass I get all 4 light on??
I feel it is a problem with a computer, module, relay? What is it called and where is it?
Thanks!
Old 03-11-2010, 11:06 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
.... What good is unplugging the dimmer swtich? That just controls the brightness of the interior lights.
Hmm, i'm not sure and i really dont want to sound like a , but did you accidently push the highbeam lever forward and forget about it? I've done that and i couldn't figure for the life of me why it was so bright out that night . Eventually, I noticed the bright blue light sitting on top of the dash.
Old 03-12-2010, 01:25 PM
I wish! It was that simple. When I say dimmer switch I was referring to the arm on the column. It is the one I unpluged and high beam and low still on?
Forgot to mention ..... no key in ignition , if I turn on the lights it starts my blower fan (inside for heat or ac)???
Old 03-12-2010, 01:41 PM
Sounds like you have some electrical problems you need sorted out. Did you hook up everything correctly for the lighting when you installed it? I assume that everything worked fine before the new lights, so I would trace back any wiring that was done and make sure it is correct.
Old 03-12-2010, 04:51 PM
Thanks for the ideas. I have tried stock 100% after and problem is still there?
Old 03-16-2010, 04:45 PM
West Pittston, PA, USA
Car: 2000 2.0 GLS Super Charged
check and see if your ignition switch went bad they're a known problem and can cause all sorts of weird problems
Old 03-16-2010, 09:41 PM
I tried to unplug the ignition switch and problem is still existing.
I also checked the fuses, relays, and fuses above battery. Looks as good as new , no melting?
Thanks!
Old 03-24-2010, 12:59 AM
I fount a mess of melted wires above the relays. It was obviously the cause of all my misery. Glad to find it before I lost the car to a fire
Tail Lights not working after replacing Brake Lights megepo0 Questions, Issues, Concerns, or Problems with the New Beetle 3 05-21-2011 01:04 PM
lights,lights,ligh...teh,no illumination.??? 70autostick Questions, Issues, Concerns, or Problems with the New Beetle 6 02-02-2010 04:03 AM
driving lights along with fog lights? dmbluebeetle Technical Modifications 14 07-09-2009 04:34 AM
LED Fog Lights AndrewC Styling Modifications 4 08-26-2008 03:58 PM
High Beam Lights and Fog lights hdtv 1.8 Liter Turbo 41 08-21-2006 05:37 PM
