Throttle Body - NewBeetle.org Forums
Old 04-07-2010, 02:35 PM
Unhappy Throttle Body
Hello,
I have a 98 VW Beetle and the initial problem started when the car was throwing the code P1582 and I looked it up and it suggesed that the throttle body is cleaned as well as the spark plugs be changed. After that was completed the check engine light went away only to return with the code P041, so I took the car to the VW dealer and they stated to me that my throttle body needs to be changed as well as R&R the ECM & Readiness Set. My question is whether or not this is something that can be worked on at home or is it a difficult part to change?
Old 04-07-2010, 06:08 PM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
Did they state the reason why the TB needs swapped? Also, what is the entire code you were referring to with P041?
Previously:
Old 04-07-2010, 10:32 PM
Sorry about that the code was P0411 and the dealer never really specified why it needed to be swapped.
FS: Used Throttle Body almsbeetle Parts and Accessories 1 08-04-2010 04:03 AM
throttle body questions. 300dollarfun 2.0 Liter Gas 1 03-09-2010 11:31 AM
checking throttle body fixit_karl 2.0 Liter Gas 0 11-25-2008 01:33 AM
I need a Throttle Body for a 99 2.0 with cruise avarvelo Parts and Accessories 0 04-22-2008 01:47 AM
