window switch working backwards - NewBeetle.org Forums
Old 05-22-2010, 03:12 AM
Default window switch working backwards
I own a 2000 new beetle with power driver and passenger windows. I had lots of electrical issues earlier that I have more or less worked out....except this one...
The passenger side window control works normally. The drivers side control works normally for the passenger side window. But the driver side control seems to have reversed itself for the drivers side window...in other words pushing DOWN on the switch makes the drivers side window go UP and vice versa. Same thing happens when I lock the doors with the key and hold it to "close" the windows. The passenger side goes up but the drivers side goes down!
Any way to reset this electrically? I can live with it for now but it is just weird!
Thanks
Old 05-22-2010, 06:53 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
I'm wondering if it's a fault in the window motor. Have you tried unhooking the battery for a while?
Previously:
Old 05-22-2010, 07:21 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Sounds like the wiring at the drivers motor is reversed (as both the switch and the ECU drive the same way, most likely is the motor wiring is reversed somehow...
Cheers
Simon
Old 05-22-2010, 04:51 PM
I had this car in the shop one week ago to have the alternator and battery replaced, so I am sure it was without power for a while during maintenance. If I were to disconnect the battery, for how long? And isn't there a radio anti-theft problem I have to address?
Thanks
Old 05-22-2010, 04:52 PM
I may get aggressive and look at that when I have a door panel off anyhow.....for now I may live with it and look at the wiring when I have to open up the door for another reason.
Thanks
Old 05-27-2010, 02:06 PM
Griffin, GA, USA
Car: 2000 TDI GLS
Lightbulb Elecrical issues
are such fun to deal with sometimes! I suggest like some above that due to 'poking about' in the wiring either at the door switch or the window motor, somehow have been reversed. I was going to suggest the switch itself had been put into the assembly upside down, but if the key operated function also works reversed, then the culprit is probably the motor wiring. USUALLY the contacts / wiring are arranged so that it's really difficult to do things backwards, but difficulty doing things wrong is only a minor challenge to 'some' techs.
Can't remember if the switches have the terminals marked, but if they do, here we go:
On the lift motor of '98 thru '02 cars, there's a red wire with white stripe on terminal T29/20 and a white wire with red stripe on terminal T29/7 which travels to the window switch, terminal T5D/1. If these are reversed at the motor the window may work reversed. On the window switch, the brown wire with blue stripe is the ground. The remaining wire on the drivers window switch is green with blue stripe on terminal T5D/3. These are in connectors that will only go in one way unless one has a terminal disconnecting tool that allows the terminals to be pulled out without damage SNAP-ON~TT600 ELECTRICAL HARNESS TERMINAL TOOL SET: eBay Motors (item 220609338037 end time May-30-10 16:30:00 PDT) . So be alert for any splices of any kind, anywhere in your car (the factory doesn't do that, you know).
Old 05-30-2010, 10:08 PM
Default reset window actuator
I spoke to the original owner this weekend. (I've only owned the car a month) and he confirms that the windows DID work correctly. We bought another key/fob for the car and had some issues reprogramming it. I am going to be this is an electronic problem. Is there a way to "reset" the window actuator. And/or do you think resetting the key fob might fix this?
Thanks
Old 05-30-2010, 10:30 PM
simonsi's Avatar
Jitterbug
Car: 2000 NB 2.0
Thanks
Nope, I think the wiring has been reversed. But IŽd be happy to be proved wrong either way I hope you find a fix for it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Trunk Switch not working ci3edi 2.0 Liter Gas 6 05-06-2010 05:18 PM
Mirror Switch still not working... RandyN 2.0 Liter Gas 3 05-05-2010 10:22 PM
Driver side electric window switch,door light and door lock not working. Bug2003 Questions, Issues, Concerns, or Problems with the New Beetle 6 06-13-2009 12:51 AM
Fuel Door Switch Not Working? hawke12 Questions, Issues, Concerns, or Problems with the New Beetle 7 11-19-2008 07:28 PM
A/C/Heater switch not working rjs77 Questions, Issues, Concerns, or Problems with the New Beetle 1 08-19-2007 04:50 PM
