Hello All,
I am new to here. I own a 2004 New Beetle Hard Top. Today my coworker helped me to change the Headlight Low Beam on the driver's side since the bulb burnt. We managed to take out the headlight, change the bulb. But when we put the whole piece back, we are stuck. We tried almost like 1 hour to try to figure out how to put it in perfectly,but we didn't make it. The result is it has a small tilt on the bottom,the light is not touching the body perfectly. The top of the light is good and touching the body. We feel there is something inside blocking us to put the headlight completely in. We decided to let it go like this,at least it won't drop on the road when I drive. But I am still not happy with the result.My coworker said we can try again tomorrow if I want. Anybody had the successful experience that can share? I would always appreciate a lot!!! |
Hi
A bit late to asnwer but I had that issue. I got the instruction here on the forum on how to replace the built in the headlight assembly. Putting it back in was not the easiest thing. It is only after understanding how the mechanism works that I was able to snap it in. there is a ring inside the housing that caches the head light assembly. Even if it's made of plastic - dirt gets into it and it as to move freely inside to catch the assembly. There are 3 screws that hold that mechanism in place. Cleaning and lubricating this rind did it for me. When you push in the assembly the 3 prong get catch by the ring and induce a rotation and the ring locks holding the housing in place. Mine is a 2003 NB convertible. I hope my experience can help someone Happy motoring ML ![]() |
You don't have it properly aligned. There are 3 tracks that you have to be perfectly aligned in order to slide back in.
A lot of people think they are lined up with the track but most of them only get two out of the three. Pull the headlight back out then look very carefully and slowly put it back in making sure all three of the tabs slide into the tracks. If you are just off by a tiny bit it will not go in all the way. And YES, the headlight could fall out if you hit a bump or a chuck hole if it isn't locked in all the way. Good Luck! |
BE CAREFUL !! If the headlight is stuck it can be difficult to get it out again. As Indytom suggested you may have missed a track which is very easy to do.
Problem now is getting the unit out again, DO NOT pull on the headlight lens as they are only glued on. The lens may come off or you break the seal and the headlight gets water in and fogs up. My advice is to push it from the back after making sure the release clip is open. I use a piece of wood with a cloth on the end so not to damage anything. You will have read by now that when the light is out, make sure the tracks and the locking ring is clean and moves freely. The locking ring is designed to pull in the the light the last mm or so when locked and secured. Have fun :-)
Steve Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me, either. Just leave me alone. |
| Tags |
| headlight |
| Put Monsoon back into Beetle with aftermarket HU | TDI_KC | Car Audio | 2 | 02-01-2010 09:40 PM |
| Grrr...Headlight impossible to put back in! | Hercules Beetle | Questions, Issues, Concerns, or Problems with the New Beetle | 14 | 01-25-2010 02:19 AM |
| Dynamat install, do you put the padding back in under the carpet | xhaus11 | Car Audio | 1 | 01-20-2010 06:30 PM |
| What's the oldest CD you own that still plays perfectly? | PhoenixRising | Miscellaneous Hoo-Ha | 15 | 12-31-2008 04:12 PM |
| Put my bug back on the cursed list. | Ringo* | The New Beetle Experience | 4 | 10-16-2007 09:33 PM |
