Key fob not opening passenger door, but locks it. - NewBeetle.org Forums
Old 06-19-2010, 04:04 PM
Default Key fob not opening passenger door, but locks it.
I've discovered something interesting that's recently developed and wondering if anyone has any insight. If i use the key fob to unlock the door, it will unlock the drivers door, but not the passenger door anymore. I can use the lock switch on either door to lock and unlock both doors, so the actuator is working fine.
I can also lock both doors with the key fob. This is a 2002 2.0L bug.
Cheers
Old 06-19-2010, 04:13 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
You are pushing the unlock button twice, right?
2000 New Beetle GLS TDI
Old 06-19-2010, 04:41 PM
Yes, i am :P
I actually just found a similar post, tried it out and it worked.
Basically I opened both windows, and locked the doors with the fob. I opened the door from the inside with the handle, alarm went off on the drivers side.
I did the same on the passenger side and the alarm didn't go off, and while the alarm was on, the door switch didn't work either. I played around with trying to get the alarm to go off on the passenger door and it finally started working again. It opens again with the fob. So all is well.
However, the alarm does not go off when the passenger door is opened from the inside. Not that I'm concerned about the alarm, just interesting observation.
Cheers
Old 06-19-2010, 10:16 PM
You might have a dead microswitch in the passenger door. Common failure. Its what tells the car if the door is open or closed.
Old 06-20-2010, 04:04 AM
I think you are correct, its intermittently working. I've read a few posts of suggested quick fixes before completely replacing the switch, which I'll try.
I'm suspecting there is a similar switch in the hatch that was causing my troubles last month, making the dash light flicker while driving, and alarm going off in the middle of the night. I slammed the hatch a few times and it stopped that for a bit, I'll have to locate that switch and try the same procedure.
Key/Fob Drivers door Switch. richamer1 Questions, Issues, Concerns, or Problems with the New Beetle 5 12-30-2009 03:22 PM
Door lock switches on door (locks) replacement? s4iscool Questions, Issues, Concerns, or Problems with the New Beetle 3 09-30-2009 12:13 AM
Difficulty opening passenger door sledsearcher Paint and Body 1 09-19-2008 01:15 PM
FS: Key Fob and blank key Xkontour98 Parts and Accessories 3 05-17-2008 11:33 PM
passenger door won't unlock with fob??? djsung815 2.0 Liter Gas 1 01-05-2007 02:56 PM
