'00 auto NB TDI running B99.
Rolled the car backward out of the garage today (not unusual) and went to turn over the engine and it didn't start. It surges (engine jumps rather drastically) as it turns over but doesn't actually start. The surging feels like the transmission is engaged. We checked and there are no codes. Everything has worked up to this point. It does have an oil leak that needs to be dealt with from the black cap over the valve cover ,opposite the oil input in front of the left portion of the air filter hose in the following photo (photo is not mine)http://image.eurotuner.com/f/2484448...tdi+engine.jpg ![]() Ideas appreciated, thank you!
Cyber Green 2000 NB TDI - Sprout - the BioBaby
Does the car actually move any? Have you tried putting it in neutral when starting?
If the TC failed catastrophically this could happen, but you would have had some symptom the last time you drove it. Does it sound like the engine is trying to fire at all? How is the timing belt, when was it last done and who did the job?
my fiance says it feels like the transmission is partially engaged so that when the starter turns over you can feel it try to surge forward which is slowing down the sarter enough so that it cannot turn over fast enough.
| Tags |
| not starting , oil leak , surge , tdi , transmission |
| Engaged | crazi_daisy | Miscellaneous Hoo-Ha | 22 | 01-04-2009 05:18 AM |
| Sort of engaged!!!!!! :-) | crazi_daisy | Miscellaneous Hoo-Ha | 12 | 10-20-2008 11:11 AM |
| Transmission Shudders when starting out | gsrogers | Transmission Talk | 2 | 06-10-2008 05:18 PM |
| I got engaged! | Lona | Miscellaneous Hoo-Ha Archive | 28 | 12-27-2006 10:20 PM |
| I'm engaged! | JrsyGrl | Miscellaneous Hoo-Ha Archive | 22 | 12-29-2005 02:54 PM |
