Go to an autozone or equivalent. They will scan your car for free and get you the codes. Let us know what the codes are. They will point you in the right direction. We can guess a lot, but the codes are where the answers are.
Did the EPC orange light come on at the top center of the gauge cluster, then the yellow engine emissions light lower left? If so and the car bogs down at slow speeds but operates normal once going faster its likely the G28 crank speed sensor. It is located on the drivers side of the engine block beside the oil cooler. It is fastened to the block with one hex key bolt right in the block.
Have you ever replaced the transmission fluid?
| Brake Light, Check engine light, air bag light, but wait theres more | djack19 | Questions, Issues, Concerns, or Problems with the New Beetle | 15 | 11-09-2011 11:13 AM |
| EPC light, Check Engine light with Codes | cathlynr | 2.0 Liter Gas | 1 | 05-25-2010 08:52 PM |
| Check engine light/Cold light periodically | bulldoggergal | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 12-17-2009 11:36 AM |
| 2001 glx + awp engine swap = check engine light!?! NEED HELP | garvitron | 1.8 Liter Turbo | 7 | 05-07-2009 01:22 PM |
