Starter engine noise - NewBeetle.org Forums
Old 08-11-2010, 08:00 PM
MN, USA
Car: 2000 VW New Beetle 1.8 Turbo
Default Starter engine noise
I have the new Beetle Turbo 2000, made in Mexico in Nov. 1999. It has just 46.000 miles on the clock. I have had noise from the starter engine nearly every time I start the car, a big screech..... The dealer says, "Oh! it's on all the new Beetles" and not to worry. Brother-in-law, Floyd the auto expert says it is the starter engine and something that is ringing out after the starter engine has fired.
Anyone else embarrassed when the starter engine screeches out to the neighbors
Old 08-11-2010, 08:10 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Lol. Mine does it too. Unfortunately, it is normal on some early turbo models
Old 08-11-2010, 08:15 PM
The starter on my 2.0 made some noises back in the winter time. Seemed to not like the cold. I was told that the starter is probably dirty and needs to be cleaned up, but its nothing bad. Also would cause no harm to leave it. No issues here, though the sound went away once the weather got warmer.
Old 08-11-2010, 11:25 PM
Fl_bug's Avatar
Miami, FL, USA
This sound (first start up, not the rest)?
Old 08-30-2010, 07:24 PM
MN, USA
Problem with Starter noise on New Beetle 2000 Turbo.
The dealer said " they're all like that" but my local mechanic just installed a new Part # 17780SW Reman Starter Motor $265.51 plus labor. Now the car is super, no more screeching when it is started.
Old 08-31-2010, 03:40 PM
Twizzler
Toronto, Ontario, Canada
Car: 2002 NB 1.8 GLX RED
Don't tell me, everyone is talking about a standard tranny right? VW issued a Technical bulletin about it wayyy back, the clutch dust goes into the starter and makes it screech. NOT ALL Beetles do that, just 98-2001 manual tranny have the potential to do it. Remedy was to simply blow the dust out with compressed air. VW put a sheild or repositoned the motor so the dust wouldn't go in it in later model years. If you have an auto then there is no screech unless you actually have a starter problem.
Old 09-01-2010, 01:04 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
You got hosed. There was nothing wrong with your starter. I would have done the whole job for $60. Remove starter, take starter apart, clean, lube, assemble, install. $5 worth of cleaner/grease and about an hour of work.
Later models have the same issue too, as do any other manual VW. In fact, its common in other makes too. Its not really doing any damage as long as it is not excessive...its just annoying.
2000 New Beetle GLS TDI
Old 09-08-2010, 08:40 PM
Pizzaboy's Avatar
Pizzaboy_Rob
CO, USA
Car: 2002 Turbo Diesel Volkeswagen Beetle
How do you clean the Starter or at least take out the second bolt that hold it in place?
Old 09-08-2010, 08:45 PM
Pizzaboy's Avatar
Pizzaboy_Rob
CO, USA
So what if you actually have a Starter problem? How would you remove the bolt on the bottom of the Starter?
My 02' TDI Diesel runs okay and occasionally doesn't start at times. (I tap on the Starter Cylinoid or get a jumpstart and She's running again.)
Old 09-08-2010, 09:16 PM
DZLBUG's Avatar
I Am Breitbart
Put the car on ramps and do it from underneath.
Its very easy to access.
Old 09-08-2010, 09:38 PM
Pizzaboy's Avatar
Pizzaboy_Rob
CO, USA
It's easy to gain access, however, can't get the bottom bolt out. :-(
Old 09-08-2010, 11:47 PM
DZLBUG's Avatar
I Am Breitbart
Get a bigger ratchet or breaker bar.
Old 09-24-2010, 03:28 PM
Pizzaboy's Avatar
Pizzaboy_Rob
CO, USA
Default Relived...
I got so annoyed at trying to take out the second bolt that I put it all back together. My yellow bug seems to have been working fine until she died on me again! Finally broke down and bought a battery, not cheap for a 02' Diesel, $156 with a 10% discount.
Starter noise captbp Questions, Issues, Concerns, or Problems with the New Beetle 15 03-19-2011 02:51 PM
Engine Noise? sjdean101 New Member Forum 1 02-14-2009 05:26 PM
Engine Noise? sjdean101 2.0 Liter Gas 0 02-14-2009 03:54 PM
Starter has hard time turning engine.... Amanda Transmission Talk 0 10-15-2007 04:40 PM
Starter Noise skiyuh 1.8 Liter Turbo 1 06-06-2007 02:18 PM
