There are two horns for the steering wheel and one for the alarm. The two tone horns are located under the drivers side bumper in front of the drivers wheel. It is unlikely both horns there are blown at the same time. It is likely the relay, #53, under the dash above your left leg when you are sitting in front of the steering wheel has failed finally. These relays are cheap on eBay or at your dealer.
Looks like this might work? http://www.partstrain.com/store/deta...3-1626580.html And if its under the dash it should be out in the open? Or will I need an installation guide on this? Last edited by tracivw; 10-09-2010 at 02:08 AM.. |
I've replaced a lot of horns, but never a horn relay that I can remember. Typically one horn fails and most of the time the driver doesn't notice. It is when the second horn fails that the driver will notice. Same thing with headlights.
![]() Take the car to a quite area, and with the ignition on but engine off, try to honk the horn, if you hear a clicking noise in the dash, then the relay is most likely fine. The horns are on a bracket held that is secured with a bolt (13mm head). Look between the bumper cover and fender liner at the left front corner. The horns can be swapped out in a few minutes with just hand tools, the hardest part is unplugging them.
| A/C Recirc stopped working?? | Haplo | 1.8 Liter Turbo | 2 | 08-06-2010 04:12 AM |
| 2009 Beetle won't start, radio stopped working | Beetle Jucie | New Beetle Convertible | 1 | 03-05-2010 12:22 PM |
| Stopped working: Horn, Headlights, fog lights, HVAC Fan and turn signals | JKbride | 2.0 Liter Gas | 2 | 07-09-2009 11:57 AM |
| Gauges stopped working?! | PlatinumTurboS | 1.8 Liter Turbo | 6 | 03-22-2009 03:00 AM |
| 2001 Stopped Working CEL & EPC lights on | zorb13 | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 10-15-2006 12:40 AM |
