driver's window won't go all the way up - NewBeetle.org Forums
Old 10-28-2010, 12:32 AM
Default driver's window won't go all the way up
My 2000 beetle driver's side window will not go all the way up, it stops at about 2 inches from being shut. Sometimes it will go to that spot and come back down. I hear no noises.Could this be the regulator? How hard is that to change?
Old 10-28-2010, 01:08 AM
DZLBUG's Avatar
Probably MIA
Blaine, MN, USA
Could be the regulator. Could just be dirty window channels. Give them a good blow with an air gun and then squirt some silicone spray down the rear channel and work the window up and down some. Repeat a couple times if necessary. I had the same problem and this has been working great for a year now.
If not, then it could be early signs of regulator failure. Its a relatively easy job if you're patient and read up on the procedure first. Don't buy the whole regulator, just get the repair kit. Should be about $50.
2000 New Beetle GLS TDI
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Locking & Driver's Window Problems dbmoylan@gmail.com 2.0 Liter Gas 6 04-15-2010 10:44 PM
Driver's side wIndow switch needed vwnb01 Market Place Archives 3 10-01-2008 02:51 PM
broken driver's side window! brokedownbeetle Questions, Issues, Concerns, or Problems with the New Beetle 4 04-27-2008 02:47 AM
driver's side window woes englishman11 Questions, Issues, Concerns, or Problems with the New Beetle 7 01-09-2008 06:32 AM
Driver's power window rbaker Questions, Issues, Concerns, or Problems with the New Beetle 5 06-10-2006 08:29 PM
