P1649 + ABS Light = ? - NewBeetle.org Forums
Old 11-05-2010, 10:39 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Default P1649 + ABS Light = ?
Just wondering, but I scanned a car that had an ABS light on. The car drove great and everything.... until it came time to stop. The brakes were very poor and felt like it was missing power.
The car had error code
p1649-Data Bus Powertrain Missing message from ABS control module
I'm going to go on a limb and say the ABS Pump need to be replaced... However, that is almost $2k in parts! Any chance there is a vacuum unplugged or bad sensor?
Old 11-05-2010, 06:18 PM
Fl_bug's Avatar
Miami, FL, USA
bump
Old 11-05-2010, 06:33 PM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Fuses are all good?
Old 11-06-2010, 12:29 AM
Fl_bug's Avatar
Miami, FL, USA
Originally Posted by NewBeetleMechanic View Post
Fuses are all good?
Yes
Old 11-06-2010, 01:17 AM
What kind of car?
Old 11-08-2010, 06:58 PM
Fl_bug's Avatar
Miami, FL, USA
What kind of car?
Check your PM Inbox.
Its on a 2003 Jetta TDI
Old 11-09-2010, 03:27 PM
Use a Digital Volt Ohm Meter (DVOM) to measure voltage at pin 7 of the Diagnostic Link Connector (DLC). If full battery voltage is present a problem in the K data communication line is indicated. Normal voltage will run from about 2.0 volts to a maximum of about 10.5 volts. Check for installation of an aftermarket radio. If an aftermarket radio has been installed, the radio wiring harness must be modified to prevent the aftermarket radio from applying battery voltage to the K data line. Remove the radio and look at the black 8 pin connector. Pin 3 of the black 8 pin connector is the K data line. Remove pin 3 from the connector and tape it back on the harness in such a manner as to preclude shorting. Replace the radio and check for correct voltage at pin 7 of the diagnostic link connector. Volkswagen Factory bulletin Group 91 bulletin # 99-0 addresses the wiring modifications neccesary when an aftermarket radio is installed. A related document, Volkswagen Factory bulletin Group 91 bulletin # 99-01, is available.
Test and fix:
If 0 volts is present on Pin 7 of the diagnostic link connector a potential short to ground in the wiring harness or a shorted controller on the K data line is indicated. Disconnect controllers on the K data line one at a time while monitoring DLC pin 7 voltage. If DLC Pin 7 voltage returns to normal after a controller is disconnected an internal short in the controller is indicated.
Old 11-09-2010, 03:42 PM
Fl_bug's Avatar
Miami, FL, USA
Test and fix:
Thankyou very much! I will be keeping this information handy! I'll let you know how it goes
Old 11-11-2010, 09:18 PM
Fl_bug's Avatar
Miami, FL, USA
Update!
Simply clearing the code did it actually. No more ABS light and no more CEL. The brakes were functioning perfectly too!!
Just in case any of this comes back, i'll be sure to give the above suggestions a peek!
Thanks Mr. Mech!
Old 11-11-2010, 11:40 PM
Originally Posted by Fl_bug View Post
Update!
Thanks Mr. Mech!
Glad to help.
No Headlights, ABS Light On, No Air, Hand Brake Light On... iScott Questions, Issues, Concerns, or Problems with the New Beetle 14 04-02-2012 01:11 PM
Flashing ABS light, traction light, bouncing tach, and beeping terror_storm Questions, Issues, Concerns, or Problems with the New Beetle 1 09-21-2010 03:36 PM
ABS light and Traction control light dpoll995 1.8 Liter Turbo 3 10-30-2009 02:08 AM
Abs light plus airbag light on at same time. SALTYDOG1960 1.8 Liter Turbo 0 01-01-2008 08:16 AM
ABS Light/Emergency Brake Light and Exhaust. :( Pashura Questions, Issues, Concerns, or Problems with the New Beetle 0 06-08-2007 04:28 PM
