So the past two days I've been abusing my beetle.
What I mean is, my driver's headlight went out randomly. I bought two bulbs, in means to take care of this simple, frustrating issue. Whilst in frustrated stage, I smacked my beetle's headlight...and it started working again. I've had to do it here and there for the past two days. I figured the filament in the bulb is deformed, or it's loose, something simple like that. I look into the issue more...I can't use my high beams. I can flash them, but I can't keep them on. I'd love to inspect the headlight but it is hidden behind the battery box, and all that good stuff. Anyone want to diagnose this? I believe I need new headlights anyway. I have to put in fog lights...so I might as well go at it.
Got an Engine or Airbag light but can't afford a Vagcom or trip to the dealership?
Need help finding a local mechanic or shop? <<credit to Fl_Bug>> (o \__(vw)__/ o) (add me!) |
I had to change my headlights 3 weeks ago. the drivers side is the easiest... as far as you can go there is a little lifter handle. lift that up and jiggle the whole assembly out. be carefull not to pull the seals off or u will need a replacement.. new one is about 500$... get the assembly out and disconnect all the plugs, i think 2... then the spot where the bulb goes has a clip, flip that over and it should come out. DO NOT touch buld, use a microfiber cloth, replace bulb, flip clip and do what you just did but in reverse... headlight should work if you did it correctly. Good luck...
It's not just a hobby, it's a love affair! |
BTW, I still have the old one. The lens popped off of it but the internals are probably still good. If you need sockets, wires, etc. let me know.
'02 & '05 Acura RSX Dodge Cummins, Ford Ranger M151 Ford "Drive less, worry more. It's cheaper." |
Every time I hit it it starts working again so I really don't know what's up. |
My suggestion is to remove the head light and remove this plastic. ![]() When you remove this plastic the female end will not have a mounting base so once you mount the light you will then have to plug it in from the underside of the fender. Someone else mentioned using die-electric greese, its a very cheap insurance policy. |
I believer her Beetle is an '00...it doesn't have that style of headlamp assembly.
It does sound like the connection is bad, though, if bumping it makes the light come on. I would remove the headlight and check to make sure the connector is pushed on all the way. |
| Driver's side brake light not working...other side is fine | adamhiggins | 1.8 Liter Turbo | 8 | 06-16-2010 07:32 PM |
| HELP! Driver's side seat.... | Dottie Beetle | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 10-24-2009 02:56 AM |
| WTB: '06 or Newer Driver's [LEFT] Side Headlight Cluster | dieseldriver | New Beetle Classifieds | 0 | 02-08-2009 09:12 PM |
| Help lights out on driver's side | Bean68 | New Member Forum | 1 | 06-02-2008 11:50 PM |
| broken driver's side window! | brokedownbeetle | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 04-27-2008 01:47 AM |
