![]() 1 Transmission Control Module -J217- 2 Engine Control Module Note: If engine or transmission control modules are replaced, the system must be returned to basic setting. 3 Data Link Connector (DLC) 4 Valve body •The solenoid valves -N88-, -N89-, -N90-, -N91-, -N92-, -N93- and N94- are attached to the valve body •The valves are checked by On Board Diagnostic (OBD) 5 Conductor strip with integrated Transmission Fluid Temperature Sensor -G93- •-G93- is checked by On Board Diagnostic (OBD) 6 Multi-Function Transmission Range(TR) Switch -F125- •-F125- is checked by On Board Diagnostic (OBD) 7 Transmission Vehicle Speed (VSS) Sensor -G38- •-G38- is checked by On Board Diagnostic (OBD) 8 -Vehicle Speed Sensor (VSS) -G68- •-G68- is checked by On Board Diagnostic (OBD) 9 -Throttle Position (TP) Sensor -G69- •Signal of -G69- is checked by On Board Diagnostic (OBD) 10 Shift Lock Solenoid -N110-. •The solenoid is checked by On Board Diagnostic (OBD) •Can be checked electrically and via reading measured value block 11 Transmission Range (TR) Selector Lever Display -Y5- 12 Cruise Control Switch -E45- •Can be checked via reading measured value block 13 Kick Down Switch -F8- •Can be checked electrically and via reading measured value block 14 Brake Light Switch -F- •Can be checked electrically and via reading measured value block. 15 Park/Neutral Position (PNP) Relay -J226- |
The following section refers only to the automatic transmission 01M and to related terms that may be found in the 01M On Board Diagnostic (OBD) section. These definitions are not necessarily generally valid.
ABS Anti-lock brake system. Display group number See Read measured value block Throttle valve control module An engine component to stabilize the idling speed. The "Throttle valve signal" originates here. On Board Diagnostic (OBD) The capability of a control module to recognize, react to and store malfunctions of various components and systems. Conducting On Board Diagnostic (OBD) Connecting a scan tool and checking the Diagnostic Trouble Code (DTC) memory. The malfunctions registered and stored by a control module are read by using the scan tool. Injection quantity influence The engine torque is reduced during the gear shift process by changing the quantity of injected fuel. Electrical test By performing certain measurements a targeted check of the electronic components is accomplished. Fuzzy-Logic Type of monitoring for the actual driving situation. This software in the control module replaces the previous program switch CAN-Bus Method of data transport. Electrical signals are carried in a certain format (BUS). CAN-Bus low (high) The voltage used to transport the data is low (high). Transmission Vehicle Speed Sensor -G38- The sensor records the speed of the large sun wheel in the planetary gearset and transmits it to the transmission control module. Vehicle Speed Sensor -G68- The sensor records the speed of the output gear and transmits it to the transmission control module (not to the speedometer) Initiating basic setting The values learned in the control module are returned to the initial values. "No communication" There is no connection for exchanging information between the control modules. Short to Ground Current flows (incorrectly) to Ground without supplying a consumer. Short to positive Current flows (incorrectly) to a live component without supplying a consumer. Read measured value block The control module can transfer a considerable amount of test data. This test data contains information on the operational condition of the system and sensors connected to it. The transferred test data can support diagnosis and malfunction correction. The test data has been summarized into single display groups due to the amount of information available for evaluation. Emergency running A condition of the control module. When certain malfunctions are recognized it protects the transmission against damage, which guarantees the vehicle may be safely driven further. During emergency running mode the driving characteristics of the transmission are impaired only as much as is necessary. Pendulum support Designation for the type of assembly (engine/transmission) mounting. Sporadic Happens occasionally TDC signal This signal is used to calculate the engine speed. Infinity Ohms The resistance is high, an open circuit is indicated. Ignition timing influence The engine torque is reduced during the gear shift process by changing the ignition timing. |
Thanks for the info on this, But ... what exactly causes them to basicly fail. some last between 100-150K then die. any idea what Fault may be in this transmission ? I had the 6sp tiptronic which i know is totally different from the o1m 4 sp.
Thanks ![]()
~Jay~" L.E.A.K.O.I.L "Fo'Shizzle 12-21-2006"
I think what he meant was that the 01M has a reputation for failing. Can you shed any light on that?
'02 & '05 Acura RSX Dodge Cummins, Ford Ranger M151 Ford "Drive less, worry more. It's cheaper." |
Well when Japan took over the build for the 01M/096 4 speed production, the transmission went to hell. First of all, production went to a forign country that had no concern for German quality. The next thing that happened was, the Japanese have a problem understanding that a electrical componant that gets variant volts/amps/ohm kills the electrical part. So you had Japan Trans electrical parts mixed with German (extreme engineered) wiring. Yes a solenoid might say made in Germany, but hell with a etching stick I could make it say "NBM has a big one", the solenoids where made in Japan.
Other problems include the internal wiring strip that controlled them. Here you have a computer strip inside and covered in transmission fluid. I would love to meet the German that thought that was a good idea in the first place. ^^^good news is that if you make your own harness for the inside of the trans, it will work FOREVER. The other assorted sensors and switchs that are continually covered in transmission fluid fail, the fluid eats away at the sensors plastics on a microscopic level. (causes the sensor to fail eventually) Bands and sprags inside (friction disks) are pretty good, problem is a sensor causes a "slip" and burns them up. The "rear end" gears are pretty good, but in stock form will only support a max of 300-325 hp? Kinda fun to take a car and hit it for a weekend drag with a 200 shot of nitro. <-dont ask, cause I aint telling. So basically when yours goes into limp mode, STOP DRIVING IT! Your trans may be saved. Kinda a side note: If you have a 2.0 or any 01M, and have to buy a new starter, buy one for a 1994 VW something 2.0L and automatic. Much better design (for the same price) I guess we get a double side note today: You can build a 01M that will take 600 hp, but I would buy a trans blanket, and use it! We have not even got to the tiptronic, yeah. The manuals are easy. My dog could probably fix a manual. His name is Scirocco, btw. Hes a problem child too. Last edited by NewBeetleMechanic; 11-10-2010 at 02:19 AM.. |
| 01M Transmission Discussion | Loosenutbehindthewheel | Transmission Talk | 45 | 05-31-2011 05:56 PM |
| Windshield wipers: Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-09-2010 06:58 PM |
| How to decode your VIN: Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-09-2010 06:51 PM |
| Comfort Control System: Information Topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 11-09-2010 06:35 PM |
| Failed emissions test? Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 11-05-2010 11:51 PM |
