How to test the VSS Vehicle speed sensor. - NewBeetle.org Forums
Old 11-10-2010, 12:54 AM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
Default How to test the VSS Vehicle speed sensor.
CHECKING SPEEDOMETER VEHICLE SPEED SENSOR
Required for troubleshooting :
•Multimeter
•Connector kit VW 1594
•Valid wiring diagram
•Repair Manual, Electrical Equipment.
Always check battery Ground (GND) connections for tight fit before troubleshooting.
CAUTION : DO NOT damage, enlarge or bend connector terminals or cavities by forcing probes in to them when performing electrical checks. Always use connector test kit VW 1594 to make the necessary electrical connections.
Prerequisite:
Instrument cluster coding MUST correspond to model and equipment particulars. Check/confirm instrument cluster coding.
Preparation:
•Switch OFF ignition and all electrical consumers.
•Remove driver's side lower instrument panel cover.
Test Steps
Old 11-10-2010, 07:29 AM
Basher's Avatar
Huskvarna, Sweden
Car: 1999 Techno Blue 2.0
Excellent, but you don't specifically need the Fluke 83 multimeter. Any type of multimeter with a continuity test and audible signal will do. And that would be basically any digital multimeter nowadays.
Old 11-10-2010, 12:59 PM
Fixed.
Old 12-30-2010, 07:20 PM
•Multimeter
Prerequisite:
Preparation:
Test Steps
It appears that the important information to test this sensor has been removed or deleted. Can you please repost?
Old 12-30-2010, 07:21 PM
Zann's Avatar
HP Technician
Macon, GA,
Car: 2002 New Beetle Turbo S
The person that posted this was a pathological liar with split personalities if I kept up with the drama correctly. This information may or may not have been correct.
Old 12-30-2010, 07:57 PM
That's a shame. I can't seem to find a test procedure for this part.
Old 12-30-2010, 08:15 PM
Tioga, TX, USA
Car: NB 2000 TDI
why do you suspect VSS bad?
Old 12-31-2010, 12:21 AM
Supercharged98's Avatar
Fountain Inn, SC, USA
Car: 2004 NB Turbo S
To test it...
1)jack up the front and secure with jack stands.
2)tranny in neutral, power off, unplug the sensor
3)put your multimeter on ohms and touch the sensor progs
4)have someone turn the drive wheel slowly, and the the meter will change back and forth (open to close) if it's good.
Hope this helps....
"Deutsche Stahl"
Old 12-31-2010, 01:06 AM
Duffy's Avatar
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Another good reason not to use external sites for posting pictures!
Tom
Old 12-31-2010, 03:30 PM
Tioga, TX, USA
Car: NB 2000 TDI
The deleted photos/doc's were intentional. The guy was an a** that got upset when he was called on questionable suggestions and went thru and deleted all the doc's he posted.
Old 01-01-2011, 04:14 AM
I am glad to have the procedure for this now. Let me take a moment to wipe the egg from my face though ... I meant to find a way to test the engine speed sensor. I have a feeling this is causing a no spark condition, but am unsure.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Convertible top repromming of vehicle speed from 3mph to maybe 25mph? 58and03beetles New Beetle Convertible 18 12-05-2010 03:48 PM
16885 Vehicle Speed Sensor - Speedo Issue v12bug 1.8 Liter Turbo 7 10-18-2010 01:22 PM
where can i buy vehicle speed sensors garay77n84 Transmission Talk 3 04-16-2008 01:40 AM
Part number for Vehicle Speed Sensor? saadah Market Place Archives 0 02-29-2008 04:23 PM
