Commercial designation
The following designations are used and appear on component Labels and factor tags: •R-134a •Tetrafluoroethane •CH2F CF3 •H-KW 134a •SUVA(R) 134a •ARCTON(R) 134a Color Refrigerant R-134a is colorless and is invisible as a gas. R-134a when viewed through the sight glass may appear milky due to the mixture of refrigerant and lubricating oil (PAG oil). Temperature/pressure relationship R-134a in an enclosed container will have a specific temperature/ pressure relationship. Temperature in °C (°F) Pressure in bar (psi) -30 (-22) 0.0 (0.0) -20 (-4) 0.3 (4.4) -10 (14) 1.0 (14.5) 0 (32) 1.9 (275) 10 (50) 3.1 (45.0) 20 (68) 4.7 (68.2) 30 (86) 6.7 (97.2) 40 (104) 9.1 (132.0) 50 (122) 12.2 (177.0) 60 (140) 15.8 (229.2) 70 (158) 20.2 (293.0) Refrigerant oil A special Polyalkylene Glycol (PAG) synthetic oil is used in R-134a systems. This oil is NOT compatible with mineral based oils used in R-12 systems. Refer to Cautions and Warnings regarding proper oil usage see page 87-1. Airborne properties Escaped refrigerant gases are heavier than air and will gather first in low places, like under the car. R-134a refrigerant gas displaces oxygen and may cause suffocation in low areas of poor air circulation. Refrigerant R-134a is not poisonous in any state (liquid or gas) and is sate when used properly. Affects on plastic Refrigerant R-134a will deteriorate some plastics. Therefore, when making system repairs, use only genuine VW replacement parts which are specified for use with R-134a refrigerant. Affects on metal In its pure state, refrigerant R-134a is chemically stable and will not attack iron, copper, brass or aluminum. However, the mixture of R-134a and PAG oil may deteriorate certain metals (copper). Therefore, when making system repairs, use only genuine WV replacement parts which are specified for use with R-134a refrigerant. Water solubility Liquid R-134a refrigerant will absorb only very minute quantities of moisture. However, R-134a vapor can absorb large amounts of moisture. Flammability R-34a refrigerant is not flammable Refrigerant containers DO NOT exceed maximum rated capacity of refrigerant container. Leak detection Use halogen leak detector Hitec H1400A-TEL or equivalent to check for R-134a system leaks. This tool can also be used to detect leaks in R-12 systems. Many currently available R-12 leak detectors cannot detect R-134a refrigerant leaks. R-134a refrigerant oil A special Polyalkylene Glycol (PAG) synthetic oil is used in R-134a systems. This oil is NOT compatible with mineral based oils used in H-12 systems. |
A/C refrigerant system pressures and temperatures, checking
The pressures and temperatures in the A/C system will vary depending on engine speed (RPM), coolant fan speed, engine coolant temperature, A/C clutch engagement, outside temperature, humidity, etc. Pressure and temperature specifications are based on the following: Engine speed (RPM) at 1500 Fresh air blower on high speed A/C adjusted to Max. cooling Pressure and temperature specifications, refer to "Pressure and Temperature Specifications" ![]() 1 - Evaporator 2 - Low pressure service valve 3 - Compressor, low pressure side 4 - Compressor, high pressure side 5 - Condenser 6 - Receiver drier 7 - Sight glass If equipped 8 - High pressure service valve 9 - Expansion valve ![]() |
A/C refrigerant system, testing with pressure gauges
Due to the constant temperature/pressure relationship of refrigerant R-134a, approximate high-side system temperature can be determined based on system pressure. Pressure gauges may have one or more temperature scales in addition to the pressure scale. Since various refrigerants have different temperature/pressure relationships, each gauge is specific for a particular refrigerant. Measuring pressure and temperature in a "switched-on" refrigerant system Use the A/C refrigerant high-pressure gauge to measure high pressure between the compressor and restrictor (including condenser) with the A/C switched on. Use the A/C refrigerant low-pressure gauge to measure low pressure between the restrictor and the compressor inlet (including evaporator) with the A/C switched on. The temperature displays of the low- and high- pressure gauges apply only to a portion of the low- and high-pressure sides. The low-pressure gauge displays approximate temperature between the restrictor and evaporator outlet. The high-pressure gauge displays approximate temperature between the compressor outlet and restrictor. NOTE: The temperature/pressure relationship only holds true when the refrigerant system contains liquid and vapor, but not when it contains only gas. In the gaseous state, the temperature is approx. 10-30°C (18-54°F) higher than indicated on the pressure gauge. Measuring pressure and temperature in a closed container or "switched-off" refrigerant system Due to the constant temperature/pressure relationship of R-12 and R-134a, approximate temperature in a closed container or in a switched-off A/C system can be determined based on its pressure. If the temperature displayed on a gauge is lower than the actual temperature of the refrigerant, the refrigerant container or system is empty (discharged). NOTE: The temperature/pressure relationship only holds true when the r6frigerant system contains liquid and vapor, but not when it contains only gas. In the gaseous state, the temperature is approx. 10-30°C (18-54°F) higher than indicated on the pressure gauge. |
NOTE: A/C evaporator temperature switch -E33- (if equipped) switches A/C compressor OFF only in special instances so evaporator does not ice up; variable displacement A/C compressor maintains temperature of 0 °C (32 °F ) in evaporator.
Test conditions •A/C refrigerant system fully charged •A/C clutch -N25- and compressor function OK •Condenser and radiator clean and free of obstructions •Air distribution can be adjusted properly •Wiring OK as per wiring diagram •Outside (ambient) temperature 20 °C-30 °C (68 °F-86 °F ) Checking •Start engine. •Set temperature control to maximum "cold". •Press A/C button and select second blower speed. •Adjust air distribution to instrument panel outlets. •Insert thermometer into center instrument panel outlet. •Raise engine speed to approximately 1500 RPM . Specified result With normal humidity and outside (ambient) temperature between 20-25 °C (68-77 °F ), system is sufficiently charged if air temperature from center instrument panel vent drops below 10 °C (50 °F ) within one minute . For higher ambient temperatures and/or higher humidity, specified air temperature from center instrument panel vent can be slightly higher. |
| U codes and you: Information topic | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-09-2010 10:09 PM |
| P codes and you: Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 19 | 11-09-2010 10:03 PM |
| Windshield wipers: Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-09-2010 06:58 PM |
| How to decode your VIN: Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-09-2010 06:51 PM |
| Failed emissions test? Information topic. | NewBeetleMechanic | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 11-05-2010 11:51 PM |
